Old 01-25-2012, 02:17 AM
OZ Duster OZ Duster is offline
Default Rubbing
Originally Posted by djorgensen3 View Post
Could you add a 1/4" wheel spacer to move the tire/wheel toward the quarter? That would seem far cheaper and easier than buying new tires if its just a short term solution.
The wheel needs to move inboard away from the guard, sorry should have been more clear.
Old 01-25-2012, 04:13 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
So it's rubbing on the quater/outer wheel house.
What bushings are in the leaf springs?
Old 01-25-2012, 04:27 AM
Running fiberglass mono-leaf, everything other than the disk brakes appears stock. Had not thought of play in the bushes will check them out in the morning. Cheers
Old 01-25-2012, 05:03 AM
jy211's Avatar
jy211 jy211 is offline
I may get yelled at for this one, but do you have a rear sway bar on it? My 68' had 1 side rub when I hit dips in the road. I installed the rear sway and that eliminated the issue.
Old 02-21-2012, 02:01 AM
Default Offset maximum on 69 camaro
After a number of checks to the rear suspension I believe the rubbing issues are the Wilwood disk brakes. The rear track has been increased by one inch over stock to 61" and has resulted in the rubbing on the guard lip. I can get a wheel I like in 17 x 8 with an ET of +15mm which will allow me to tuck the wheel up in the rear (compensating for the increased track). The Same wheel on the front will result in a ~ 5" back space, the current 18x8 ET 0 (4.5" backspace) appears to have ample clearance all round. Is this acceptable on a 1969 camaro with Wilwood disks?
spacers are illegal in Australia so that is out of the question before it is offered up. I see a lot of camaros on here with massive wheel size and width just need to know if the back space mentioned is suitable
Cheers
