Old 08-15-2012, 12:02 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Picked the car up on Monday and got back out in the garage last night.
Exhaust sounds great but I've encountered new gremlins (at least I hope they are gremlins and not major problems).
The main thing that prevented the car from being driven in the past was front tire clearance and interference of one of the two pinion down bars on the rear end. After thrashing on other parts of the car I decided that the one pinion down bar was strong enough for a mild drive and threw my old front tires on and took the car for a real drive (as opposed to loading it on/off trailers).
It was not a confidence boosting drive. After warming up the oil I was getting 20 PSI at idle and 40 at high RPM. I also have significant engine vibration above 1500 RPM.
I am hoping I did the noob LS move so many others did and screwed up the oil pick up tube o-ring install when I swapped to the Autokraft pan and that is my oil pressure problem. If not then I don't know what to do next?
I am stumped by the vibration. It's 100% related to engine speed. Will vibrate in neutral sitting still in the driveway when you rev up the motor. vibrates driving at speed until you push in the clutch and/or shift into neutral at which point the vibrations are gone.
Since it was a new crate motor (did sit for 3 years before being run), new RAM flywheel and GM LS7 clutch I'm not sure how to diagnose it. I'm guessing it has something to do with the flywheel/clutch. Would bell housing run-out effect this? Pomona Valley Customs assured me they checked it and it was fine but after seeing their other work I have my doubts. Can you screw up an LS7 clutch install and cause vibration but otherwise have a good working clutch? What would you guys check?
I was supposed to participate in the Super Chevy Handling challenge but after last nights voyage there is no way I can make it.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
