Old 07-03-2012, 10:55 AM
geberhard's Avatar
geberhard geberhard is offline
Default Swapping a ls1 and t56 intoa first gen, pedals, etc?
So have a donor convertible LS1 Z28 witha T56, and am swapping the engine and tranny into a first gen (Firebid 68).
The Firebird had manual 3 speed and a Chevy engine 307 at some point which I already removed. So the car currently has the pedals for manual in place (gas pedal has a cable so that is also great). I am wondering if I should utilize the pedals from the donor as well, or use the pedals I have in place?
Thanks!
Gui
Old 07-03-2012, 12:27 PM
Rybar's Avatar
Rybar Rybar is offline
Use the stock pedals. but depends on the gas pedal. Post some pictures.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 07-03-2012, 12:38 PM
geberhard's Avatar
Thanks, gas pedal currently on first gen is the desirable one with cable (not rod style), so believe would work).
I am not sure what the clutch pedal setup will be like, I believe the one on the 67 is normally mounted pivoting from the side of the engine through a bracket, I believe no clutch master cylinders on the first gens), not sure how people have modified their setup to work with the clutch Master Cylinder?
thanks!
Old 07-03-2012, 02:04 PM
MaxHarvard's Avatar
Just use the one you have. You will probably have to adjust the cable though as the lengths and routing will not be the same.
Old 07-03-2012, 02:13 PM
Rybar's Avatar
thanks!
You will need a firewall bracket for the clutch like this one:
http://www.speedtechperformance.com/...rod/prd212.htm
1969 CAMARO RS
Old 07-03-2012, 02:18 PM
MaxHarvard's Avatar
I have that one and it works perfectly.
Old 07-03-2012, 09:03 PM
Z06vette's Avatar
Z06vette Z06vette is offline
If you use the stock pedals with bracket listed above, you will also need a shorter clutch master rod available from speedtech. Old rod end is removed from 4th gen master & new one is put on in place of it & welded. Only other thing you will likely need to do if using all 4th gen hydraulics is make a pedal stop. The pedal will not go all the way to the floor, so travel will need to be limited to avoid damaging the master. I'll see if I can find the part # for the speedtech rod.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 08-17-2012, 07:22 PM
imjustjames imjustjames is offline
I can't wait to do the LSX swap!!
Old 08-17-2012, 08:01 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Scott I am glad you mentioned about the clutch master rod. I have the willwood hydraulic clutch master cylinder with a long clutch master rod due to which the clutch master cylinder is mounted on a homemade bracket, and this bracket is mounted to the firewall. I will try to post a photo of it sometime this weekend.
Really appreciate If you get the part number for the short master rod.
72 Camaro RS:SOLD
68 Camaro:
Old 08-18-2012, 09:31 PM
Z06vette's Avatar
Default clutch rod
It appears they are advertising the clutch bracket & the modified heim joint as a package now. If you already have the bracket, give them a call & im sure they will sell you the rod end joint separately. Scott
69 RS LS3/T56
67 RS LS2/T56
