Old 12-11-2012, 10:29 AM
syborg tt's Avatar
I have 18 x 8 with 5.75 back spacing with a 24.5" tall front tire and it hugs the inner wheel lip very tight.
The only problem I had was the front end was still a little high so I added drop spindles to get the top of the tire even with the wheel well arch. In doing so the rim hit the outer Tie Rod. In order for it to work I install a set of Bear Tracker Hiem Joint tie rod ends and a 1/4 spacer.
If you go with Stock Spindles you will not have a problem. I was recently told that CPP makes a drop spindle that will clear a 9" rim. But I have not confirmed that yet.
marty-mj
Old 12-11-2012, 11:04 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
First off, I have been following your Gen II build for a while now. I love the car but hate the fact that you have convinced me that I must have a tiger cage LOL.
As I sit right now Im going with the following:
2'' Drop spindles, CAC bump steer linkage, CAC upper/lower's (Anvil wheel wells if need be)
Front:18x9 5.25/5.5bs 265/35/18
Rear:18x12 5.5bs 335/30/18 57'' flange to flange housing
Opinion?
Thanks for the response
Old 12-11-2012, 12:02 PM
syborg tt's Avatar
Opinion?
Shoot me an email and I'll send you pics of the spindle mods I did.
mr2879sy @ aol.com
marty-mj
Old 12-11-2012, 02:49 PM
brownz brownz is offline
Like Marty's car my setup is also hugging the outer lip of the fender and even had to make a small clearance to it. My car is a little low in the front and will be bringing it back up a little. If you are on protouring.com you could pm Mary Pozzi about her car. I know that she ran a 18x9 with a 275 tire but she is from what I know going with a 295 tire and fender stretch.
Old 12-24-2012, 05:27 AM
NorCal72's Avatar
@Marty- I attempted to email you but it didnt work. [email protected] is mine if you get time.
Im going with the 9 on a 255 so I will see how that goes for the time being. Thanks for the help!
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 12-28-2012, 07:14 PM
syborg tt's Avatar
email sent
marty-mj
