Old 01-15-2013, 08:55 PM
Datsbad's Avatar
Datsbad Datsbad is offline
So I take it a DSE unit won't work? I bought the subframe new from a friend, who got it straight from Wayne. I think I had to buy the rack from Wayne, no idea where he was getting them modded, if that is indeed the case.
no DSE unit is different slightly. a SN95 rack has the right dimensions to bolt up. Have to change out the ends or disassemble the rack and modify. Not a big deal . Theres more to the story . Customer has never driven this car 1 miles . Insisit's it has PS steering but then says were doing a DSE front frame and LS with Quadarlink very soon to it.....Just a waste of money .
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 01-15-2013, 08:59 PM
camcojb camcojb is online now
well, sounds like he has plenty of money, and as long as he's willing to pay twice for it, then that's good for you.
Old 01-15-2013, 09:03 PM
Datsbad's Avatar
yeah ... but I end hearing it later even after he made the decision... know what I mean .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 01-15-2013, 09:32 PM
Geez --- Too bad I sold the one I had hanging in the shed from the ceiling! It had P/S....
Old 01-15-2013, 11:58 PM
Geebus Weld, you got sheet all over the place. LOL
Hey Jason, I have an early early Wayne frame, Might even be a Rasmusen frame. I found that it was different, a bit wider and we found that they used a mid 90's Caravan outer tie rod to make it work. Thst might help you out.
Old 01-16-2013, 04:20 AM
Rick D's Avatar
Rick D Rick D is offline
Leave it to you Greg, only you would have a sub frame hanging from the ceiling!
Rick
Old 01-16-2013, 08:12 AM
I'm a "newbie" to this whole car hot rodding thing....
Old 01-16-2013, 11:46 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I have an early wayne due frame w/C4 suspension/C5brakes. Its been a while, but when I was trying to find out what rack was on it the match was 93 cobra mustang and/or 94/95 cobra. I dont know if this will help you or not but I figured it couldnt hurt. The LS1 pump has too must assist on this rack for my liking. Its great for autocross, but on open track w/higher speeds it will be too twitchy for me. Right now Im running a smaller restricter in the pump,which helps, but I will evemtually have the rack revalved.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 01-16-2013, 12:12 PM
That's a problem with running a GM pump and a Ford rack.... There is a valve replacement for that on the high pressure side of the pump. But I agree = it's close but not perfect.
Old 01-17-2013, 07:13 PM
coolwelder62's Avatar
I am almost sure you could a DSE (24.5)rack(The DSE unit use's 9/16 mounting bolt's on 15.5"center's).Might have to use some .750 O.D X .058 wall tube to make a new thur mounting sleeve.The DSE unit are revalved for GM pump PSI.
