Old 04-09-2013, 01:23 PM
DRJDVM's '69's Avatar
The car has been in bare metal for quite awhile now.... when I had it blasted I did epoxy it but with all the metal work 80% of the original epoxy is gone. So now that I'm finally winding down on the big metal work, I need to get it back in epoxy. So I prepped and shot the doors, front fenders and trunk lid.
So that's where it stands right now for the most part.
Right now I put the car back on the rotisserie and am going over all the welds and doing final grinding/dressing etc. I'm going to have Dominator weld on my brackets for the rear UCA front mounts (any high stress areas, I'm having the pros weld on...don't trust my own enough)....then I'm going to take it back to the blaster and have them "touch it up" by blasting all the underside, floor and any spots really difficult to get to (seams, welds etc) and then get it back into epoxy.
Then mock it all up again, and start my hard lines for brakes, fuel, brakes etc
Old 04-09-2013, 01:26 PM
hey Marty
The rear UCA ?...no its the same length....maybe a turn or two different. I tried to run it in the middle of its threads to give me as much adjustment longer/shorter as possible. Other than that, its the same length as it comes form Ride Tech
Old 04-09-2013, 01:35 PM
syborg tt's Avatar
Originally Posted by DRJDVM's '69 View Post
hey Marty
yes I did have Tim shorten those front UCA a tad and the camber improved a lot. I'm still kinda worried about alignment adjustment with the way the front is set up now....we shall see...
On the Airbar set up on my Camaro we bolted and did a couple stitch welds.
marty-mj
Old 04-09-2013, 02:08 PM
Looks good, Ned!
Old 04-09-2013, 02:25 PM
Rybar's Avatar
Rybar Rybar is offline
Does look good Ned, nice progress and thanks for the update.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-09-2013, 04:41 PM
E.rodz's Avatar
E.rodz E.rodz is offline
Nice to see your still at it progress is golden keep chipping away a little at a time just keep your eye on the prize. you are going to run into alot of hurdles when you take on a build of this nature and you are doing a great job overcoming them. great job on the build keep up the great work!
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
