Old 07-05-2013, 06:08 PM
Operations's Avatar
Operations Operations is offline
Default SEMA 2012, 1969 Camaro, who built it?
I saw this 1969 Camaro at SEMA, it was outside under the Magnaflow tent.
What I'm really interested in is what suspension is used up front, I see the ZR1 OEM wheel and ceramic breaks. That ZR1 wheel backspace is way out there, and I can’t find anyone's subframe / suspension working with that wheel offset.
here is a link to a pick I found later online.
Thanks in advance for you help
Old 07-06-2013, 05:45 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Any subframe using C5/C6 parts will use wheel offsets like that. It's probably a DSE or AME.
Old 07-06-2013, 05:57 AM
Bryan O's Avatar
Bryan O Bryan O is offline
I don't think those are ZL1 wheels. Here's a pic of the ZL1 wheels:
Bryan
Project Alchemy
https://lateral-g.net/forums/showthread.php4?t=29820
Old 07-06-2013, 07:16 AM
clill's Avatar
clill clill is offline
LOL..He said ZR1
Old 07-06-2013, 09:33 AM
Bryan O's Avatar
oops.
Bryan
Project Alchemy
Old 07-06-2013, 11:08 AM
Operations's Avatar
Thanks for the replys
The ZR1 Front wheel is a 19X10 +40mm offset (7.1" backspace)
I called DSE verbally they said no. Although I did not get their recomended "wheel backspace" (if anyone knows please post)
SpeedTech recomeneded max width is 9.5" with +32mm (6.5" backspace)
Thats about 5/8" diffrence, not sure if that will be a problem, cuz I have never suffed fat rubber under a 69.
If anyone has experiance otherwise please chime-in and let me know.
Im years in the Corvette world, and just stepping in to my 1st 1969 Camaro Pro touring build.
thanks
Old 07-06-2013, 12:47 PM
Ventura Ventura is offline
Default DSE subframe
DSE recommends a max of 6.125
Old 07-06-2013, 01:59 PM
Ron in SoCal's Avatar
I'm running an 18x10 w 6.9 bs on my 69 with an Art Morrison sub. Not sure if a 19" wheel would complicate things as its pretty close now.
Ron in SoCal
69 Camaro in progress
Old 07-06-2013, 02:34 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
If you had a 1" spacer made for the fronts, you could run that wheel with a 275/30/19 and it would be roughly the same height as a 275/35/18, I think.
Old 07-06-2013, 03:12 PM
badmatt's Avatar
badmatt badmatt is offline
Those are the spyder wheels are they not?
97 Sonoma "NERA": Pile O Sh*t. Literally.
