Old 09-07-2013, 05:03 PM
inkman101 inkman101 is offline
Default New shoes, new stance, new problems
I just finished up my 70 ElCamino with new rims and tires and supension upgrades. It has Sc&c stage 2 plus front suspension, with matching springs(2 inch drop). My new problem is the emergency brake hits the frame. The rear is a Dana S60 with older Baer set up. Any ideas????Name:  DSC00550 (800x600).jpg
Name:  DSC00549 (800x600).jpg
Name:  DSC00542 (800x600).jpg
Old 09-07-2013, 05:37 PM
No familiar with those brakes but could you swap sides do the e-brake cables are at the bottom of the setup instead of the top?
John
'71 Nova (Build thread)
FFR Roadster
Old 09-07-2013, 07:04 PM
randy randy is offline
get us some more pic please. DIfferent angles if possible
Old 09-08-2013, 02:00 PM
I will get more pic's on Monday.
thanks Pete
Old 09-10-2013, 08:15 AM
John at SC&C John at SC&C is offline
I have a similar Baer set-up currently, and my caliper points to the rear of the car (not up). The brake cable comes out of the bottom of the caliper. Where is the bleeder for the caliper located ? Looks like it would be pointed toward the front of the car (again, not up). Any trouble bleeding them?
Savitske Classic and Custom
610-381-6100
'87 Buick Regal Turbo T
Lots of SC&C - SPC, Howe, Currie, Hellwig
Spohn, Varishock, Fays2 Watts Link
Baer 12" Discs - all 4
Boze Pro Touring Wheels
Old 09-10-2013, 04:44 PM
It's a bad angle, it's on top. Thanks for the pic.
Pete
Old 09-11-2013, 04:08 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Looks like you'll need a new bracket to position the caliper down away from the frame. I'd ask baer what else they have, or ask KORE3.
If the calipers can be swapped to the other side, and if that positions the cable bracket down, you may be able to bleed the caliper off the bracket, with the bleeder up, and then mount the caliper.
Old 09-11-2013, 09:01 PM
U-turn U-turn is offline
Swap sides. I had to do that on my car.
Old 09-12-2013, 06:51 PM
Do you have any pic's.
Thanks pete
Old 09-12-2013, 07:34 PM
Sieg's Avatar
Sieg Sieg is offline
Can you simply clock the caliper bracket 90* on the axle?
