Closed Thread
Old 11-06-2013, 06:50 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default Ford 9" Housing
Mild Steel, Mig welded fabricated housing.
Extra Strong, Extra Light, and designed to minimize gear oil slosh and keep the gear oil where it belongs. Cleaning out the garage and need gone.
Name:  IMG_3066 - Copy.JPG
$500 plus shipping (located in Mesa, AZ)
*same rear housing that resides in JCG's "2nd Test Car" (see below)
[IMG][/IMG]
Old 11-06-2013, 07:53 PM
Rick D's Avatar
Rick D Rick D is offline
How wide is it and what size axle tubes??
Rick
Old 11-07-2013, 05:15 AM
Default 9" Housing
Rick, I will post exact width this evening when I get home to measure, but it is un-cut/full length and will accommodate the widest of car applications. Axle tubes are 3". Thanks, Jay
Old 11-07-2013, 05:56 AM
carbuff's Avatar
carbuff carbuff is offline
While you are measuring, could you take a second dimension for me? Specifically how far is it from the furtherest rearward face of the center section to the back of the axle tube? My application is really tight there due to the Watts link mount, so that would be a critical dimension...
Old 11-07-2013, 07:25 AM
Not a problem. Will let you know this evening. Jay
Old 11-07-2013, 04:50 PM
Housing is approx. 53" end to end. So basically once housing end of choice (ie. torino end) are welded on, then brake package,,,, this un-cut housing would finish out with an approx. 61" WMS to WMS which is wider than any application I am aware of around here. Thanks, Jay
Old 11-07-2013, 04:52 PM
Putting a straight edge along the back and butting the rear side of the axle tube measures approx. 4" Thanks, Jay
Old 11-10-2013, 04:26 PM
To The Top...
Old 01-28-2014, 07:09 PM
To The Top...
Old 02-08-2014, 07:43 PM
To the top....
Closed Thread
