Old 12-27-2013, 08:18 AM
Scotts Hotrods Scotts Hotrods is offline
Supporting Vendor
Originally Posted by ccracin View Post
It's looking really good guys. One question, have you checked the turning radius with the foot area extended? My guess is you have really limited yourself unless you moved the cab on the chassis or moved the spindles forward on your chassis. I would really like to know if this works since I'm taller than average!
Again, looks awesome!
The front wheels at full compression have plenty of room.When the front wheels are turned lock to lock there is plenty of room.The front centerline
of the wheels are moved forward 1 inch from stock.We do this on our c-10
chassis and our c-10 ifs kits.This will center the front wheel into the fender.
Old 12-27-2013, 08:39 AM
ccracin's Avatar
ccracin ccracin is offline
Awesome, I figured you guys were on it! Can't wait to see more. Thanks for the reply!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-27-2013, 10:06 AM
tech@scotts tech@scotts is offline
Supporting Vendor
I'll shoot a few pictures so you guys can see the frame and firewall clearance. We set them up with the wheels set forward 1". As it sits right now, there is a ton of room between the firewall and wheels. I think the mock ups are about 3" shorter than the actual wheels/tires being used, but even with that, there's plenty of room.
Camren Beattie
www.scottshotrods.com
Old 12-27-2013, 10:09 AM
Supporting Vendor
Originally Posted by 214Chevelle View Post
Looking good! I thought you guys were gonna do a tube chassis? Looks good either way though.
I guess it just depends on what the definition of tube chassis is. We build some chassis's with round tubing, and build some with square tubing. We wanted our typical "off the shelf" chassis under this one to represent what would be typical if someone were to call an order one. I have a few round chassis cars I'll take a few pics of for you guys. They do look pretty cool.
Camren Beattie
Old 01-02-2014, 12:34 PM
Supporting Vendor
Right now the guys are setting up the ground clearance. The rockers are being trimmed and remade, ad the rear of the cab is being redone too.
You can see just how much we are taking out of the rocker. Seems like a lot, but it'll really not be noticeable when it's all finished.
Camren Beattie
Old 01-02-2014, 03:03 PM
Supporting Vendor
The body will sit level with the frame when it's finished. All said and done, it will give us our 4" of ground clearance that we need.
Here's a better view of the rocker. It'll be finished with a sheet metal cap and shaped correctly.
Camren Beattie
Old 01-02-2014, 03:23 PM
syborg tt's Avatar
I can't wait to see this one finished.
marty-mj
Old 01-06-2014, 04:33 PM
Supporting Vendor
Not the best of pics cause the cars pretty low on the ground, but here's a pretty much finished rocker.
Camren Beattie
Old 01-06-2014, 04:34 PM
Supporting Vendor
Well, the roof's off
Camren Beattie
Old 01-07-2014, 08:40 AM
Z06Joe Z06Joe is offline
Absolutely love this style truck!!!! This is gonna be a bad ass build for sure!!! Gotta keep my eye out to win this!!!!
