  #33
Old 01-16-2014, 07:49 AM
toddoky toddoky is offline
Originally Posted by gerno View Post
I saw the headers in your pics and it is pretty bad. Engine wise I'm looking forward to the LS and even though I don't "need" it I may dive in and get it done so I can track the car this summer.
Hopefully you can help Mike to figure the issue out. I was going to try the new hooker setup as well but the pics have me very nervous and really thinking to go with Kooks instead.
I shared your concerns last night as well when I saw the Mike's photo...that was until I discovered Mike is running a modified subframe for which our components were not designed to fit. If you look at the photo I attached to this thread this morning, you will see the intended fitment and ground clearance on a stock subframe car. I think we'll be able to figure out some method of helping Mike out too, which is a goal of mine. As long as you are running a stock subframe, you will not encounter what Mike has and will have the same ground clearance that is shown in the photo I posted.
