  #35
Old 02-04-2014, 01:48 PM
HIFLYR's Avatar
HIFLYR HIFLYR is offline
Yes which model do you have?
Temperature coming out of the vents at max AC?
Any more insulation in the car than stock?
Weatherstripping in good shape and sealing properly?
How many extra holes in your firewall?
Air conditioning doesn't make cold air, it removes heat. If more heat keeps coming in it can't keep up, no unit can.
Ok it is a early gen 2
do not remember temp but the temp differential about was about a 20 degree drop "which is really what you are looking at not just temp"
Just the stock insulation
weather strip and sealing new and good
no holes
I know how AC works but volume comes into play also or else a 1 ton home unit could cool a 5000sf home. There was a thread about the same issue about a year ago.
