Old 02-25-2014, 05:49 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Had the same dilemma. I built my own, works great.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 02-25-2014, 06:33 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
the Vintage Air LS Frontrunner is the most compact I have seen,I have bought 4 of these kits and they are super nice.http://www.detroitspeed.com/Drive-Sy...t-runner.html#
Old 02-25-2014, 08:47 PM
carbuff's Avatar
carbuff carbuff is offline
I've been really happy with my Wegner setup. I don't know how they compare in terms of being compact with the Vintage Air setup, but it has to be pretty close. Mine does have AC, but I know they have plenty of kits such that you can determine which works best for you.
http://s41657.storefront-solutions.c...?CategoryID=38
The WAK-033 kit is really nice because of the high-wrap on the PS pulley, although it does have AC.
Old 02-26-2014, 03:43 AM
chichirone's Avatar
chichirone chichirone is offline
2x re:Wegner. We are running it on our 73 TA. It's much more compact than the accessory drive on my 69 Camaro from Speed and Performance. The guys at Texas Speed recommended the Autokraft oil pan and dingo motor mounts and I've had good success with the DSE motor mounts. Check out Mark Stielow's build thread Camaro XV for some great info regarding parts selection and build recommendations. Good luck with the install. Sounds like a cool project.
Jay
1973 Trans Am "KLRBRD"
1969 Camaro SOLD
2014 Stingray Z51 SOLD
Old 02-26-2014, 10:08 AM
Solid LT1 Solid LT1 is offline
Ventura Speed Center LS drive from their SEMA 68 Camaro. Reasonably priced looks good, easily installed.
Old 02-26-2014, 06:48 PM
jlwdvm jlwdvm is offline
Interesting.....how did you get this done? Looks great! Thanks for all the help.
Old 02-27-2014, 03:02 PM
youthpastor's Avatar
X2 on the Vintage Air- nice piece
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 02-27-2014, 05:16 PM
.....I'm not sure Vintage Air makes a kit for a non-AC application.
Old 02-27-2014, 05:33 PM
67machrod 67machrod is offline
Check out drivejunky.com. I just ordered a kit today from them.
Old 02-28-2014, 01:57 AM
65_LS1_T56's Avatar
I started with a F-body setup. The low mount alternator was occupying the same space as the steering box so it had to move. I didn't want air on it and I never cared for the look of the the ps pump and alternator hanging off the drivers side and nothing but an idler on the passenger side.
So I found and alternator with side lugs and started with it infront of the ps cylinder head and worked it out from there. It basically is 10mm (.394") further forward than the F-body accessories are stock. I moved the tensioner to the old alternator position and made a bracket for that and the power steering pump too.
The balancer is SB Chevy for a bolt on pulley from ATI with a short March pulley with a spacer to position the drive belt inline.
It was a lot of work to design and machine all the brackets but it does work well and is pretty compact too. As you can see, there is good belt wrap on everything, something I was planning for as I was figuring it out.
Hope that helps,
Aaron
65 Chevelle
Project G-Velle
Project G-Vette
