Old 12-11-2014, 04:24 PM
rickpaw rickpaw is offline
Default 65 Mustang-Ridetech 4 link with DSE mini tubs
I'm about to start on a friend's 65 Mustang fastback. The car will have DSE tubs and Ridetech 4 link. I looked up the instructions for both kits, and it looks like the Ridetech set up uses the stock frame rails, while the DSE tubs require narrowing the stock frame rails.
Question: will Ridetech 4 link work with DSE mini tubs? It looks like the airbar will need to be narrowed to match with the new DSE frame rail.
Thoughts/comments?
Tu Ho
Old 12-11-2014, 05:12 PM
DBasher's Avatar
DBasher DBasher is offline
I think you're right on the money Tu. It looks like the straight bar will need to be narrowed at least back to the angled supports.
Old 12-11-2014, 06:48 PM
Yeah. Hopefully someone from Ridetech can chime in. Since he already ordered the DSE/Ridetech parts, I'm wondering if Ridetech can narrow the airbar, based on the measurements from me?
Tu Ho
Old 12-15-2014, 12:54 PM
Smittys67's Avatar
Smittys67 Smittys67 is offline
You will need to narrow it up yourself. Should not be to hard.
Chris Smith
Smittys Custom Auto
www.smittyscustomauto.com
Purpose Built Cars since 1999
Complete Turn Key Builds Custom Fab and Chassis shop
Dealer for Ridetech, Detroit Speed, Vintage Air, Billet Speacalties, Forgeline, Flamming River, No-Limit, SoffSeal, Wilwood, American Autowire, BeCool, Moser Engineering, MotorState and many more
Old 12-17-2014, 12:03 PM
rodney@ridetech rodney@ridetech is offline
Smitty is correct, the rear shock mount would have to be narrowed to fit the narrower inner width and to match the new angles of the rails.
Old 12-17-2014, 01:31 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
The inside of the frame rails, where the RideTech crossmember bolts in, doesn't move. You are narrowing the frame rails themselves, as in they were 2" wide before and now they are 1" wide.
You may be wasting your time narrowing the rails with that 4link. The lower bar will be the limiting factor in getting more tire under the car, not the wheel tub. You could leave the frame rails alone and a 295 might clear the lower bar with only a 2" deeper tub instead of the full 3".
Donny
Old 12-18-2014, 06:37 AM
I'm installing the DSE minitubs, and the instructions call for removing the stock frame rails and weld in the new rails, which in turn changes the interior width between the rails.
So I can either modify the Ridetech cradle, or narrow/reinforce the stock frame rails (which CJ Pony did to their 65 fastback SEMA car). CJ Ponny also moved the lower bar mounting points inward as well.
Tu Ho
Old 12-18-2014, 06:46 AM
Got it, forgot about the new rails part. I even went and looked at my mustang and was still thinking Camaro........
Donny
Old 12-27-2014, 01:22 PM
strtcar strtcar is offline
Any suggestions on different rear 4 link to take advantage of the tubs?
Old 12-28-2014, 05:14 PM
:shrug:
DSE? You can come and see mine if you want, you're not far.
Donny
