Old 08-29-2015, 11:38 AM
Mac&Otto Mac&Otto is offline
Default I'm Back
Well, ive found new life and some time to work on the car again. I brought the car home, the whole nose is here and I just got my dash. I had a friend in Spokane pick up some chromoly tube and we're going to build a skeleton to mount everything. I unloaded it this morning so hopefully in the next month I will have it ready to tear down and start prepping for paint.
Old 08-29-2015, 11:48 PM
I was starting to wonder what happened to you. Welcome back!!
Old 08-29-2015, 11:50 PM
Wait chromo? Specs?
Old 09-01-2015, 08:54 AM
Wait chromo? Specs?
I'm using chromoly tube for my core support and to mount my fenders, rs nose and bumpers. I figured I have taken this much time to be "weight conscious" I better use chromoly. What do you think?
Cal
Old 09-01-2015, 10:10 AM
grendel grendel is offline
Cal
Sure, you can go with smaller, lighter tube by using ChroMoly.
Then again, that stuff doesn't really see any real impact, etc, so why use something so expensive. Thin wall HREW would hold it just fine, I think.
I get using ChroMoly in roll cage that protects you, but in this use case, it's just supporting weight, right?
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 09-01-2015, 11:29 AM
Pretty much. I'm probably going overboard but I've pretty much went overboard since I started the project. Lol
Might as well be consistent!!!
Thanks, Cal
Old 09-01-2015, 02:43 PM
If you are planning to build your cage to pass tech, check the rules first.
1.750 .120 wall tubing is usually the norm in a rule book. Using ChroMo will be pointless as it will not offer a weight savings.
Old 09-01-2015, 04:34 PM
Thank you sir.
