Old 04-09-2015, 09:21 PM
fleetus macmullitz's Avatar
Default Nice to see a build that's 'universally' accepted-;)
Old 04-10-2015, 06:49 AM
Justin@EntropyRad Justin@EntropyRad is offline
Default Unreal...
You put carbon on anything, and I'm in lust
Old 09-13-2015, 06:12 PM
We have to thank Dan again for revising the final vission of G5.R. We loved the white but with so many of them in white, we felt we would need to do something a little different. Also remove the bars off the lower grille and recess it further in. Same thing with the upper and converted the fog light pods to brake ducts.
Old 09-13-2015, 09:25 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
please tell me it's going to be at SEMA.
Old 09-13-2015, 11:25 PM
syborg tt's Avatar
syborg tt syborg tt is online now
Can't wait to see it this year.
Marty-MJ
www.garagescene.net
marty-mj
Old 09-14-2015, 06:34 PM
Wish I could be there to see it.
Old 09-15-2015, 09:06 AM
syborg tt's Avatar
Not to worry I will take a bunch of pics
marty-mj
Old 09-15-2015, 11:35 AM
I live Vicariously through your photos!
Old 09-17-2015, 06:55 AM
x2 really excited to see this car complete, and, Marty, your photos are really appreciated
Old 10-18-2015, 08:01 AM
We hit a snag with the paint. Wont bore you with the details. Hopefully it will be there.
Here are a few pics of the detail work.
Justin figure out a way to installed the hood latches without having the cut out open the bottom side of the hood to access nuts that hold down the Aerocatch like you see in the picture below.
Basically, its a billet bezel that has a tap for the screws to insert into, eliminating the need for nuts. The two studs are mounted to the bezel. they allow you to hold the bezel in place as you bolt the latch into the bezel. Once the bolts are installed, you remove the studs and install the two remaining bolts. The bezel sandwiches the catch without any nuts.
The only thing you'll see from the bottom of the hood is the 1/2" hole for the pin.
Six coats of clear to smooth the bottom before one last coat of satin clear.
