Old 10-04-2015, 07:20 AM
bsharpe bsharpe is offline
I spent a lot of time trying to align the subframe on my firebird. It is not easy with these cars especially on jackstands. I understood that my unibody was not perfect (the pinch welds are destroyed and she has been hit), the ford 9" and 4 link isn't perfect (I didn't measure enough when I installed it) and my subframe has some issues but I didn't expect to run into major problems and spend as much time as I did.
I used a laser level and old vinyl tiles under the jackstands to level the car. I then plumb bobbed from everything that was symmetrical on the car like holes in the frame and the pinch welds. I used a chalk line to find the center line of the car. I then squared the rear axle to the body by taking cross measurements and wheelbase measurements. I then tried to square the subframe to the rear axle. I was unsuccessful and found major issues with my subframe. I am now evaluating my options.
Old 10-04-2015, 08:03 AM
These cars have "issues" -- they're not exactly spring chickens... they've had a rough life... The point is - that you either have to get the body back to where it should be - or you have to modify things to get all of this to line up and be square and the wheelbase to be right. Whatever course that takes is a matter of skill and pocketbook... etc.
When I did my brother in laws Camaro - it had taken a hit on the driver side... so much so that I had to pie cut the area where the steering wheel goes thru the firewall... and I had to make a "spacer" to take up the area under the floor between the floor and the sub mount. We didn't have another way to fix this "alignment" issue. We made it work and the car drives perfectly. And his gaps are perfect. The key is to have accurate measurements so that you can "fix" the issue and know what you're doing. You can fix anything if you know where you need to be when you're finished.
Check out this "spacer" I had to make for the driver side! I milled it to the .001 of an inch... just because... there was really no reason to get that close other than I just like using some of my tools. HAHAHAHAHAHAHAHA
It worked out just fine!
Old 10-04-2015, 11:27 AM
snappytravis's Avatar
snappytravis snappytravis is offline
To much Dukes of Hazards in the old Days!
Old 10-04-2015, 04:12 PM
That is why I spent so much time measuring. I know now that the Scott Mock subframe is the problem. I wanted it to be the body but the real and major issue is the subframe.
Old 10-04-2015, 04:13 PM
Wow.... never heard that before.... LOL
Sorry. Yeah -- that sub has more than a few issues.
Old 10-04-2015, 05:28 PM
I hoped for the best because I have one of his original subframes which was built before he had any issues and everybody loved his subframes but that was before Ron Sutton taught everybody to measure and tune their suspension.
Old 10-04-2015, 05:34 PM
It's such a shame -- I really liked Scott.... and he was a good contributor here. Sometimes - like Jeb Bush said - Stuff happens. For whatever reason his quality control took a giant dump. Sad.
Old 10-05-2015, 09:11 AM
jlwdvm jlwdvm is offline
I was able to get my wheel base measurements nearly the same on each side (less than 1/16" difference, and the sub is nearly centered between the pinch welds. I stopped at "nearly" because who knows how accurate the pinch welds are!
