Old 10-04-2015, 05:12 PM
bsharpe bsharpe is offline
The point is - that you either have to get the body back to where it should be - or you have to modify things to get all of this to line up and be square and the wheelbase to be right. Whatever course that takes is a matter of skill and pocketbook... etc.
That is why I spent so much time measuring. I know now that the Scott Mock subframe is the problem. I wanted it to be the body but the real and major issue is the subframe.
Old 10-04-2015, 05:13 PM
Wow.... never heard that before.... LOL
Sorry. Yeah -- that sub has more than a few issues.
Old 10-04-2015, 06:28 PM
I hoped for the best because I have one of his original subframes which was built before he had any issues and everybody loved his subframes but that was before Ron Sutton taught everybody to measure and tune their suspension.
Old 10-04-2015, 06:34 PM
It's such a shame -- I really liked Scott.... and he was a good contributor here. Sometimes - like Jeb Bush said - Stuff happens. For whatever reason his quality control took a giant dump. Sad.
Old 10-05-2015, 10:11 AM
jlwdvm jlwdvm is offline
I was able to get my wheel base measurements nearly the same on each side (less than 1/16" difference, and the sub is nearly centered between the pinch welds. I stopped at "nearly" because who knows how accurate the pinch welds are!
Old 10-22-2015, 08:31 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
That video talks about using pins in the front alignment holes which is good, but it says nothing about using the rear alignment reference holes which are located just forward of the front leaf spring mounts. These rear reference holes are intended be used to cross measure the sub frame for square much more precisely than the pinch weld. Using the rear reference points in conjunction with the front alignment holes, I was able to square my sub to within 1/64" front to rear and side to side.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 10-29-2015, 11:27 AM
Black93GT's Avatar
Black93GT Black93GT is offline
Now that's the tidbit of info I'm looking for. Thanks!
