Old 10-17-2015, 01:56 PM
JKnight JKnight is offline
These would look so good on an air-cooled 911 Turbo.
Old 10-17-2015, 07:46 PM
transam's Avatar
transam transam is offline
Make sure you buy quality barrels. The wheel industry is full of junk with great marketing. Theres a few barrel companys i could list for you but most of them are wholesale only. You can try contacting thatcher at independant wheel and if you give him your inner bore of your barrel and tell him they are 40 hole and he should be able to get them made for you. Being that they are 40
Hole i assume they are standard sizing like forgeline hre iforged etc . Theres step lip and rolled step lip. Yours are the regular step not rolled step so confirm that your new ones will ne the same. They fit the same its just a different type of edge. I rebarrel all my own wheels and have done a few sets, its actually fairly easy .just make sure you use a neutral curing silicone and clean everything like you will be eating off them and torque the bolts to spec.
Make sure whoever you use does good work. Ive seen many "professionals" do poor work.
I cant vouch for these guys but wheelflip.com and threepiece.us both offer barrels for retail and rebarreling if you want them to do it.
Old 10-18-2015, 09:19 AM
jeds jeds is offline
I second doing it yourself once you find barrels. It's really easy to do, it just takes a little time.
Dow Corning 832 RTV works well for sealant.
Old 10-19-2015, 09:19 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Yep, I did a set of Forgelines myself. They sent the hoops and recommended a Loctite product, don't recall the number of it. It was like $70/tube, but was enough to do four wheels easy.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 10-19-2015, 10:50 AM
RENN SCHNELL RENN SCHNELL is offline
I would measure the barrell ID as well.
For sealant use Dow Corning 732, $12.00 on Amazon. Wet your index finger and lightly smooth the sealant.. Allow 24hrs to fully cure before mounting tires.
Good luck!
Old 10-19-2015, 12:42 PM
Mr.VENGEANCE Mr.VENGEANCE is offline
yea I plan on doing it myself.. I did it before just more interested in who makes good lips and barrels ya know
Old 10-19-2015, 01:37 PM
transam's Avatar
Ive used american rim supply barrels before and http://www.amcrimhalves.com/Rim-Halves/ , they claim they get their supply from triangle hard alloys who are a supplier to hre.
This place offers stainless barrels which will give you a better shine and easier to maintain finish than aluminum but with added weight and cost
http://www.tunershop.com/Wheel_accessories/Outer_Lips
Old 10-22-2015, 02:13 PM
Hot1970Nova Hot1970Nova is offline
AMC rim halves are all Triangle product, that is true, and they are decent quality. The other option is ARS rim halves in San Diego, who supply HRE and Forgeline, as well as many others. AMC is easy to order from because of the way their site is designed. ARS spins them right at their facility but are set up wholesale only.
