Old 01-07-2016, 06:06 PM
clill's Avatar
clill clill is offline
I like it..
Old 01-07-2016, 06:33 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Use the money that you didn't spend going to Vegas last year
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 01-07-2016, 06:57 PM
DBasher's Avatar
DBasher DBasher is offline
Lance you know what it takes to be competitive in CAM and road racing... Take the purchase price, multiply that by 5 and you've got yourself a FUN car, heck throw a turbo on the 6 and an 8.8 rear and it'd be a fun little sleeper.
To answer some of your questions. A cage and subframe connectors do wonders for unibody cars. I'm not sure if this early of a falcon will take mustang bolt ons or not but that seems like the way to go to keep the budget in check. It's a great looking car but to be competitive I think you'd just be using the shell.
Life's short, I say you do it and post up all the info here!
Old 01-07-2016, 07:37 PM
SSLance's Avatar
SSLance SSLance is offline
You mean that money that is now rebuilding and upgrading Barney's engine?
That would end up being about what I've got in Barney now...and probably close to right. The end result would be much different though.
What is weird is I had a dream the other night that Barney was stolen out of my garage (while engineless no less) and I spent quite a lot of time trying to think of what I would replace it with.
Lance
Old 01-07-2016, 07:41 PM
craig510's Avatar
craig510 craig510 is offline
This is my Falcons build thread:
https://lateral-g.net/forums/showthread.php4?t=39876
It was reasonably competitive 2 seasons ago, but now that the fast guys are on 315's and larger it is a little off pace.
Most of the 65-66 Mustang parts will work for suspension. The exceptions are the steering center link and the leaf springs. Mike Maier Inc makes an early falcon specific coil over upper arm with excellent geometry and uses a JRI shock. I have the prototypes on my car. The 70-73 mustang spindle has the strongest pin and the correct geometry. If you want to run larger than 225 front tires you will need some custom spindles. We are also working on a MOD2 torque arm that is a little narrower to fit the Falcon's frame rails. I should have it under my car in the next 6 weeks.
With a V8, 5 speed and decent sized wheels and tires you will be right around 3100 pounds. Add a cage and some safety gear and you are right at the 3200# minimum.
Old 01-07-2016, 08:15 PM
Just the fact that Charley likes it - means I wouldn't get it..... Because then he'll start on you with "you know what you need.....?"
I've always liked these cars. Two cars is expensive - by a factor of X... more importantly - ask Charley how much TIME it takes to mess with a bunch of cars.
Old 01-07-2016, 09:32 PM
qnitro's Avatar
qnitro qnitro is offline
Eat or be eat'n
Old 01-08-2016, 06:01 AM
SSLance's Avatar
That was exactly the car I was thinking of when I first saw the picture of the red one....
Lance
Old 01-08-2016, 07:41 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by qnitro View Post
Sweeeeettt!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-08-2016, 08:46 AM
1transam 1transam is offline
^^^ further questions?
1967 Chevelle "Pay the Man"
https://lateral-g.net/forums/showthread.php4?t=45303
2012 ZL1 Camaro "Paper filter stock"
