Old 01-07-2016, 06:19 PM
SSLance's Avatar
SSLance SSLance is offline
Default So I am not a Ford guy at all...
But a friend of mine that I had NO IDEA has this car...just offered to sell to me.
My mind is going about 30 different directions... I think someone needs to build this into a SCCA CAM car or or even a track day car. It's small, light, has killer lines, and most importantly is not a basket case. It's a 1962.5 Falcon Futura with a 1968 6 cylinder engine and 1964 C4 trans, so you don't have to worry about cutting up a numbers matching car...
I have more pics of it, but have never seen it in person. It's about 3 hours away from me. So what is the consensus? Is this a good platform to build off or is the fact it's a light unibody too hard to make handle?
Lance
Old 01-07-2016, 06:24 PM
DBasher's Avatar
DBasher DBasher is offline
Falcons are dumb.
Old 01-07-2016, 07:06 PM
clill's Avatar
clill clill is offline
I like it..
Old 01-07-2016, 07:33 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Use the money that you didn't spend going to Vegas last year
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 01-07-2016, 07:57 PM
DBasher's Avatar
Lance you know what it takes to be competitive in CAM and road racing... Take the purchase price, multiply that by 5 and you've got yourself a FUN car, heck throw a turbo on the 6 and an 8.8 rear and it'd be a fun little sleeper.
To answer some of your questions. A cage and subframe connectors do wonders for unibody cars. I'm not sure if this early of a falcon will take mustang bolt ons or not but that seems like the way to go to keep the budget in check. It's a great looking car but to be competitive I think you'd just be using the shell.
Life's short, I say you do it and post up all the info here!
Old 01-07-2016, 08:37 PM
SSLance's Avatar
You mean that money that is now rebuilding and upgrading Barney's engine?
That would end up being about what I've got in Barney now...and probably close to right. The end result would be much different though.
What is weird is I had a dream the other night that Barney was stolen out of my garage (while engineless no less) and I spent quite a lot of time trying to think of what I would replace it with.
Lance
Old 01-07-2016, 08:39 PM
SSLance's Avatar
I like it..
Lance
Old 01-07-2016, 08:41 PM
craig510's Avatar
craig510 craig510 is offline
This is my Falcons build thread:
https://lateral-g.net/forums/showthread.php4?t=39876
It was reasonably competitive 2 seasons ago, but now that the fast guys are on 315's and larger it is a little off pace.
Most of the 65-66 Mustang parts will work for suspension. The exceptions are the steering center link and the leaf springs. Mike Maier Inc makes an early falcon specific coil over upper arm with excellent geometry and uses a JRI shock. I have the prototypes on my car. The 70-73 mustang spindle has the strongest pin and the correct geometry. If you want to run larger than 225 front tires you will need some custom spindles. We are also working on a MOD2 torque arm that is a little narrower to fit the Falcon's frame rails. I should have it under my car in the next 6 weeks.
With a V8, 5 speed and decent sized wheels and tires you will be right around 3100 pounds. Add a cage and some safety gear and you are right at the 3200# minimum.
Old 01-07-2016, 09:15 PM
Just the fact that Charley likes it - means I wouldn't get it..... Because then he'll start on you with "you know what you need.....?"
I've always liked these cars. Two cars is expensive - by a factor of X... more importantly - ask Charley how much TIME it takes to mess with a bunch of cars.
Old 01-07-2016, 10:32 PM
qnitro's Avatar
qnitro qnitro is offline
Eat or be eat'n
