Old 09-10-2017, 07:45 AM
SSLance's Avatar
SSLance SSLance is offline
Stuff is about to get real...
Everyone knows I've needed a brake upgrade on Barney for years...MANY years in fact.
Ever since finding out about Ron Sutton developing a kit to adapt Stoptech brake kits onto Pro-Touring cars, I've known that's what I wanted for Barney. I only want to do this once and I want to do it right!!
The issue causing the long delay in installing them was there isn't a kit available to adapt the brakes to the stock G-body metric spindles I currently have on the car. I spent SO much time dialing in the front end geometry and the steering based on these stock spindles, I was hesitatant to just install another set of spindles...knowing what it would take to keep the geometry optimized. What you see in the picture above is everything that I'll need to use to dial the geometry back to (and hopefully even better than) what I currently run.
This is no small undertaking but with Ron's guidance, some perseverance, and probably a few choice four letter words...I hope to have the new spindles installed in the next week or so.
Then... THEN... We can get around to upgrading the brakes to the best brake kit out on the market... Stoptechs...
I can't wait!!!
Lance
