Old 09-05-2017, 04:38 PM
dhutton dhutton is online now
Awesome build and skills.
No matter what you do the rocker will not be totally sealed and moisture will accumulate. A couple of drain holes would be a good idea so that moisture can escape.
syborg tt (12-28-2020)
  #152
Old 09-06-2017, 10:38 AM
Originally Posted by Goosesdad View Post
Hi Trey. I kept a 1" wide sliver of the rocker that I bent up if you want to use as a template, glad to send to you, not sure if it will be exact on your car but it might give you a place to start. I kept with Dr. Hermance's concept of not flaring out the rocker but just letting the door line continue down.
I appreciate the offer but I'm so far out from doing body work that it would be lost. I'm sure someone else might be able to use it.
Thanks John.
Old 09-14-2017, 12:04 PM
Goosesdad's Avatar
Thanks Don!! Yep, totally agree. I sealed the inside of the new rocker with Zero Rust before I put it up and I sprayed Eastwood's frame rail seal inside the existing rocker. I decided to leave the existing rocker as I don't think the weight savings was worth any potential chassis rigidity. I will include some drains....I agree with you, these areas seemed to have been designed to gather as much water and debris as one could find! - I wish I had picks of the leaves I took out when I stripped the car!
Have a great day!
John
My Build Thread:
Old 09-14-2017, 12:11 PM
Goosesdad's Avatar
Started finishing the rockers.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
  #155
Old 11-01-2017, 09:55 AM
ma73z's Avatar
ma73z ma73z is offline
Not sure how I missed this build, seriously awesome work! I wish I had your sheetmetal skills. Please keep the pics coming.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 11-04-2017, 10:38 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Yeah this is an awesome build to watch.
Curtis
Old 12-30-2017, 11:00 PM
Goosesdad's Avatar
Thanks gents!!
Have a great day!
John
My Build Thread:
Old 12-30-2017, 11:23 PM
Goosesdad's Avatar
Combined the install of a 2.5 gallon oil tank with finishing the fab of the extended rocker panel. Thanks to many here...Steve, JJ, Tim McGilton and others for the concept and advice!
Used a 1" tube through the rocker to provide access for a bolt to attach the front fender. Even though I've done everything I can to eliminate any water from getting down here, I still prepped the metal to withstand the elements.
These access holes will be covered by a splitter...coming later.
Had to push the tank into the interior just a bit.
Sealed off the rocker.
Sealed off the interior.
Will have to relocate the filler and install a site tube. Prepped for this but will wait until I'm routing the oil lines.
Have a great day!
John
My Build Thread:
Old 12-30-2017, 11:30 PM
Goosesdad's Avatar
Test fitting the Fesler flush glass. Fits well!
Have a great day!
John
My Build Thread:
  #160
Old 12-31-2017, 07:21 AM
grendel grendel is offline
Attachment 64079
Let me know how that goes. I am still tempted.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
