Old 12-25-2017, 12:24 PM
LS swap would be my 1st thing to tackle.
Old 12-26-2017, 12:32 PM
gofastwclass gofastwclass is offline
I agree but I'm not the best for an unbiased opinion since all my vehicles use an engine from the same engine family...
However IF the current power plant is running well and meeting your needs...
I build my own junk...
Old 12-26-2017, 05:23 PM
garage_engineer's Avatar
garage_engineer garage_engineer is offline
I know an LS definitetly would make a ton of sense on this car! It would be easy to do since it's already set up for fuel injection and the motor mounts, headers, etc are all readily available. I tossed the idea around for a bit but in the end I decided to stick with the ol' small block for a couple of reasons though:
1. Price - I know LS's can be had for pretty cheap but the motor I have is running well and I can save some money but sticking with it. Not saying I can't build a nice LS in the future though!
2 . Uniqueness - I wanted to stick with the small block for now to have something a little different. You don't see too many small blocks anymore, especially with the cool looking Super Ram intake! Once I get it out of the car, resealed and checked over I'm hoping she should run nice and smooth for a while.
Old 12-27-2017, 06:03 PM
Continuing on with the disassembly process despite the 10deg temps here in Mass! My little garage heater is working overtime to keep my work space bearable.
I have the fuel rails and injectors off the car. I'm thinking these are Ford "blue" injectors from the 5.0L Cobra... can anyone help me to confirm that? If so, they are 24lb injectors and I think these might not be sufficient for my 350 if they are flowing correctly. I got the following from onallcylinders.com:
injector size in lbs./hr. = (Max. HP x "Brake Specific Fuel Consumption") / (number of injectors x duty cycle)
So...
Max HP = 350 (estimated)
BSFC = 0.5 (estimation for a modified, naturally aspirated engine)
# of injectors = 8
Duty Cycle = 0.80 (the amount of time injector is open versus the total time between firing events; .80 is safe for an OE injector)
(350 x 0.5) / (8 x 0.8) = 27.34 lbs./hr<-- Looks like I need bigger injectors... any thoughts?
I'd like to send them out to get rebuilt and flow tested as well... any suggestions on who could do this?
I also managed to remove the transmission crossmember and started working on getting the transmission out from under the car. I tried supporting it with my floor jack and a piece of wood, but definitely did not feel comfortable doing it that way. That T56 is heavy! I ended up heading over to Harbor Freight and grabbing a small scissor lift to use. I don't mind buying tools like this if it makes my life easier and I'm going to use it again in the future.
Old 12-27-2017, 06:48 PM
DBasher's Avatar
DBasher DBasher is offline
Navigator injectors are blue, Cobra are black...must be some kind of hybrid ��
Old 12-28-2017, 02:49 PM
Your math is correct. They most likely were pushing the injectors harder, meaning a higher duty cycle. Assuming your injectors are 24lb injectors. YOu can safely push injectors to 85 and 90% if necessary. Just depends on what you need, what's available, and what your fuel pressure is.
According to this link https://www.injectorrx.com/bosch-fuel-injectors/ They are 25lb/hr injectors.
They'll work just fine for you. You can always increase the fuel pressure, too. I recommend a dyno tune or at least a dyno session with O2 reading once you get the car together. You may find power but you'll determine if the engine is safe more importantly
Old 01-01-2018, 05:40 PM
Thanks for the tips Trey. I am sending the injectors out to get flow tested before they are rebuilt to make sure they are actually 24lb/hr. If they aren't I'll be on the lookout for a new set. Dyno tune is also definitely in order. Might be tough finding someone around here who can do it though... most shops are LS based and I don't know if anyone has the ability to burn me a custom chip. I'll need to research that for sure.
Originally Posted by grendel View Post
In for the build.
Nice to see a Masshole doing something
Just doing my part... hopefully you are keeping warm up there in NH!
Old 12-29-2017, 01:32 PM
grendel grendel is offline
In for the build.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
