  #19
Old 03-25-2019, 06:08 PM
Panteracer's Avatar
Default Dreamin Tas
Andrew
Jeff at Midwest did not get it on the website yet
So I have 755 hp and his m-23 is good for 800 hp
I might tweak things later so his m-24 is good for more
It is an ultra case. Sealed bearings both ends better cooling
Dipstick 2 drain plugs and better gear angles
It still has all the good stuff as the m-23 lightened main shaft
Upgraded shift shafts and synchros etc. I am also getting the polished
Gears with ratios of 2.20, 1.50, 1.17 and 1.1 a lot better for
my engine with a .750 roller cam. The Engine did not like the Tko
Gearing at all. Give him a call if you want all the details
I almost bought a reconditioned Jerico but decided not to go that route
