Old 10-04-2019, 06:02 PM
Beechy's Avatar
Beechy Beechy is offline
Default Good lookin' ride
Brian, congratulations on completion, great color/wheel combo. Enthusiastic pit crew!
Question (not complaint) : how come so little caster? I would have thought at least 4* if not 6*? Seems like the alignment shop has used generic 68 Camaro reference data (which gives the red and green highlights) rather than contemporary set-up numbers?
Do you know the specs from your front clip vendor?
Jim Grant
Melbourne, Australia
(Dual citizen)
Old 10-04-2019, 07:07 PM
Brianstanford Brianstanford is offline
thank you! wheels ended up matching by luck lol. found them used on craigslist after i picked the body color
front subframe is stock, with a ridetech level 2 kit. handed the ridetech instructions to the alignment guy and said this is what i need
from my instructions when i bought the kit in 2015 - Have the alignment shop set the car with ½ degree negative camber, 2-3 degrees positive caster, and 1/8” toe in.
double checked my instructions with what is online now 2019 and they are different.....now online - Have the alignment shop set the car with ½ degree negative camber, 3-5 degrees positive caster, and 1/16”-1/8” toe in.
Instagram @brianstanford
Old 10-05-2019, 01:47 AM
Beechy's Avatar
This caster setting sounds better.....assuming the arm geometry is the same as yours (same part number upper and lower wishbones) this will give better turn-in, slalom and high speed stability.
Jim Grant
(Dual citizen)
The Following User Says Thank You to Beechy For This Useful Post:
Brianstanford (10-05-2019)
  #174
Old 10-05-2019, 01:53 AM
What about tire wear? Car will be 100% street use for now, no foreseeable track use
Old 10-05-2019, 06:57 AM
dhutton dhutton is offline
I would add a little more negative camber to help avoid any tire rubbing. -.5 degrees is good imho.
Too much caster can result in a fair amount of jacking. I had quite a bit of caster with my Ridetech Tru-Turn setup and the steering joints were groaning when I turned the wheels. Those heims are not very forgiving of dust etc imho....
The Following 2 Users Say Thank You to dhutton For This Useful Post:
Beechy (10-05-2019), Brianstanford (10-05-2019)
  #176
Old 10-05-2019, 01:54 PM
Already had some rubbing. Replaced the outer fender bolts with button heads and made some room with some hammer taps. No more rubbing
The Following User Says Thank You to Brianstanford For This Useful Post:
will69camaro (06-01-2020)
  #177
Old 10-05-2019, 02:15 PM
I did the same thing.
There is a classic car cruise on 20th if interested.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 10-05-2019, 03:53 PM
Add some negative camber for increased margin.
  #179
Old 10-05-2019, 04:15 PM
Beechy's Avatar
Default Caster
99% of driving miles are run straight ahead, caster doesn't affect the angle of the tire relative to the pavement, so does not affect wear. It DOES improve stability and "return-to-center" after turning.
During turns, caster tilts the outside wheel inboard at top so preventing tire "tuck under" thereby improving tire life.
Extreme caster (8* and more) will cause tire wear and is too much on a wet road with low profile tires.....car will PUSH BAD.
Four degrees is very conservative.
Everybody needs "slalom" when that autonomous Tesla comes out of the side-street.......not just for autocross guys.
VERY simple explanation (there are other factors at work)::::Caster is the difference between shopping cart wheel flutter, and a bicycle when u push it along using the seat only. Caster being the angle of the head stem where the steering bearings are.
Jim Grant
(Dual citizen)
  #180
Old 10-05-2019, 08:13 PM
Where at? Give me some details please
