Old 05-21-2020, 06:34 PM
F'in mine's Avatar
I guess it really pays to have friends in high places, very nice!
How about going to some thing like this for paint with matte black accenting, paying homage to the original hugger orange. Would love to see this combo on a 69.
https://www.bmwblog.com/2016/06/18/s...arousel-192842
1969 Camaro SSRS
Simon
The Following User Says Thank You to F'in mine For This Useful Post:
syborg tt (05-29-2020)
Old 05-21-2020, 07:50 PM
colorado80439 colorado80439 is offline
Ya how cool would it be to see a Hugger orange Stielow build!
The Following User Says Thank You to colorado80439 For This Useful Post:
will69camaro (05-22-2020)
Old 05-21-2020, 10:04 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Mark...... I wonder if you would have some input on brake line size. I know a lot of your recent builds have ABS. What size brake line do you use? I'm using the DSE master (GM part) and booster on my 69 ...I will be making all my own brake lines and was looking to use 3/16" for the entire car. I know GM used 3/16 in the front (disc brakes) but ran 1/4" to the rear? Could you shed some light on what you normally do with your cars?? Thanks in advance.
Old 05-22-2020, 05:38 AM
Stielow's Avatar
Stielow Stielow is offline
On my builds I do 1/4 lines to the ABS module and 3/16 to the corners. In general if you copy what GM does it will work. GM and most OEMs are either cheap, worried about safety or durability. For ABS the bigger line is need to supply the volume of fluid needed for the ABS module. For a passive system that you are not gong to track 3/16 for everything should be good. If I was going to track the car with big brakes I would do 1/4 to the tee for the front and rear systems, Then 3/16 to the corners.
Mark
Stielow Engineering
The Following 8 Users Say Thank You to Stielow For This Useful Post:
69hugger (05-23-2020), camcojb (05-22-2020), colorado80439 (05-22-2020), DKz Garage (05-22-2020), Goosesdad (05-22-2020), kwhizz (05-22-2020), syborg tt (05-29-2020), WILWAXU (05-23-2020)
Old 05-22-2020, 08:01 AM
DKz Garage's Avatar
Mark
Thank you for your input!!
Old 05-24-2020, 09:18 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Mark
Would you do the same size lines 1/4 to the tee front and rear with manual big brakes for the track? Note: 7/8" bore size master cylinder and caliper piston area spec'd for a manual big brake setup
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 05-25-2020, 06:18 AM
Stielow's Avatar
If I was building it I would use 1/4. I think 3/16 would be fine.
I don’t have any good data on passive brakes. I have not used them for 12 years.
On my older builds I did 3/16 to the front tee.
It worked.
Mark
Stielow Engineering
Old 05-25-2020, 08:33 AM
Musclerodz's Avatar
Mark
The reality of just how far ahead of the curve Mark is. Playing on another level. Everyone else still trying to figure out what master cylinder to use.
Mike Redpath
Musclerodz & Customz
facebook page
The Following 5 Users Say Thank You to Musclerodz For This Useful Post:
130fe (05-25-2020), camcojb (05-25-2020), dhutton (05-25-2020), eville (05-25-2020), fleet (05-25-2020)
Old 05-22-2020, 03:07 AM
Stielow's Avatar
The hard part is designing a one off bezel. Dakota Digital made the process very easy.
It is available to anyone.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
F'in mine (05-22-2020), syborg tt (05-29-2020)
