Closed Thread
Old 08-12-2024, 02:29 PM
I really wish I remember who it was many moons ago made a power mirror set up for those mirrors
The Following User Says Thank You to raustinss For This Useful Post:
camcojb (08-12-2024)
  #442
Old 08-12-2024, 10:01 PM
TechNova TechNova is offline
I use G-Body sport mirrors. They are remote operated from the factory. They have a cable on them stock. I make new mechanical parts for them to make them manual adjustable.
I have tried a few different ways of doing it. This is not easy. I knew someone would eventually ask the question so here are a few photos. To get it to fit in the housing is a lot of trial and error.
Thanks, I will play around and copy that, like trial and error. In the 80's I tied off the manual cable inside the door and it worked but I want to do a little better now.
The Following User Says Thank You to TechNova For This Useful Post:
camcojb (08-13-2024)
  #443
Old 08-14-2024, 07:13 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
I might be remembering wrong, but wasn't there a C3 power version?
Scott from NJ
The Following User Says Thank You to BonzoHansen For This Useful Post:
camcojb (08-14-2024)
  #444
Old 08-14-2024, 07:16 AM
Curious why G body - are the bases better suited for 1st gens? Like a better angle, etc.
Scott from NJ
  #445
Old 08-14-2024, 07:28 AM
Stielow's Avatar
Stielow Stielow is offline
Default Hobbs Camaro (Old Drag Car)
https://www.ebay.com/itm/38719416483...mis&media=COPY
They bolt on with studs (more solid) and have a slightly longer neck.
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
214Chevy (08-15-2024), BonzoHansen (08-14-2024), camcojb (08-14-2024), dhutton (08-14-2024), Ketzer (08-15-2024)
  #446
Old 08-16-2024, 07:34 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Mark, are these mirrors direct replacement for 68-69 camaro mirrors?
72 Camaro RS:SOLD
68 Camaro:
The Following User Says Thank You to 72Z/28 For This Useful Post:
camcojb (08-16-2024)
  #447
Old 08-16-2024, 08:13 AM
Stielow's Avatar
Define direct replacement. It is not a direct replacement. Some assembly required.
Stielow Engineering
  #448
Old 08-16-2024, 08:13 PM
72Z/28's Avatar
Thanks for the reply. I mean if the base of the G Body mirror and the stud spacing match with the 68 camaro mirror base, so there is no need to drill holes at different locations to fix the G Body mirror.
72 Camaro RS:SOLD
68 Camaro:
  #449
Old 08-18-2024, 05:05 AM
Stielow's Avatar
Yes you need to drill two holes and sort out what to do with the remote mirror control on the drivers side.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
72Z/28 (08-18-2024), camcojb (08-18-2024)
  #450
Old 08-20-2024, 04:36 AM
Stielow's Avatar
My full old man exhaust system. I’m tired of loud cars. I’m using a used set of 2018 Corvette Z06 LT4 catalytic converters and a AP muffler.
Hooker cast iron exhaust manifolds and 2.5 inch exhaust.
Stielow Engineering
The Following 15 Users Say Thank You to Stielow For This Useful Post:
03fridge (08-20-2024), 214Chevy (08-20-2024), camcojb (08-20-2024), colorado80439 (08-20-2024), dhutton (08-20-2024), dontlifttoshift (08-20-2024), fleetus macmullitz (08-20-2024), Goosesdad (08-20-2024), Juggernaut (08-20-2024), Ketzer (08-20-2024), PTAddict (08-20-2024), Roger M (08-20-2024), srode1 (08-20-2024), syborg tt (08-20-2024), WSSix (08-20-2024)
Closed Thread
