Old 09-29-2019, 12:27 PM
Love it. Appreciate your goal focused builds. Wish I had the talent and the attention to stick to a car plan.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 09-29-2019, 12:46 PM
payne payne is offline
What a killer build. Love it!
Originally Posted by Try2paz View Post
Mark long shot but what are your thoughts on trying to make this all work in CA and Smog legal? My understanding is that you have to transfer the fuel tank and support EVAP from the original vehicle?
I did a CA legal swap on a 1993 RX7 with a 2002 Camaro donor back in 2005-2006 (before the E-Rods).
It was not that bad, all things considered. Only real PITA was the evap system for the fuel tank. I ended up fabricating an adapter to put the OEM Camaro fuel bucket into the RX7 tank.
It may take you a few trips to the BAR Referee to get every little detail ironed out; however, I'd not hesitate to give it a go seeing how well everything fits in the truck.
One wildcard - check to see if the donor is of the same category/class as the truck in the eyes of CARB. IIRC, you can't put a medium duty motor in a passenger vehicle and vice versa.
Old 01-07-2020, 06:21 PM
Stielow's Avatar
Stielow Stielow is offline
Check out the March issue of Hot Rod for a story on the Blazer.
Stielow Engineering
Old 01-07-2020, 07:11 PM
clill's Avatar
clill clill is offline
So that makes how many times you have been on the cover of Hot Rod ?
Old 01-07-2020, 07:13 PM
Stielow's Avatar
Default 1978 Blazer
I’ve have vehicles on the cover of Hot Rod 5 and 1/8 times
Stielow Engineering
Old 02-16-2020, 06:24 PM
Mark,
So what mufflers did you switch to to get rid of the drone
? What was the previous mufflers used?
thanks,
Jim
Old 03-04-2020, 07:12 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Well done Mark nice to see Camaro's aren't all you build great I enjoy looking at all your builds cant wait to see whats next up!
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
