Old 12-27-2012, 12:23 PM
Track Junky's Avatar
Thanks Dave, that was an interesting read.
Amazes me how you guys continue to raise the bar with each build.
Gaetano Cosentino
Old 12-27-2012, 01:10 PM
clill's Avatar
clill clill is offline
Don't give em a reason for even fatter heads.
Old 12-27-2012, 02:18 PM
glassman's Avatar
glassman glassman is offline
Can fatter heads process more data?
Cause this s#\+s awesome
Old 12-27-2012, 11:32 PM
you can only pull so much foam out of a helmet.
Old 12-28-2012, 07:32 AM
Radlark's Avatar
Radlark Radlark is offline
LMBO!!!!
Old 12-28-2012, 02:28 PM
Dave and Mark too, would locating the different fluid to air exchangers in separate spots be better? Or do you run into other obstacles such as air flow and packaging that cause it to be too cumbersome or add too much weight? I'd also imagine aero considerations have to be factored in there too. Instead of having one central area to concentrate on having proper air flow through, you'd have multiple.
Old 12-31-2012, 03:55 PM
Stielow's Avatar
Stielow Stielow is offline
On Red Devil we ran the diff, tran, engine oil good and power steer was all sent to the front of the car to be cooled. On Mayhem we move the trans and diff cooler to the back to reduce the thermal load on the front. Mayhems engine coolant temp as very on track but we are still chasing an engine oil cooling issue. On Camaro XV I'm adding an even bigger rad and oil heat exchanger.
But as we attempt to rebalance the thermal load Thomson is upping the power..
I think we can keep it cool and make more power.
Mark
Old 12-31-2012, 03:57 PM
coolwelder62's Avatar
Mark
Old 12-31-2012, 04:09 PM
Mark
I'm probably going to step out on a real thin limb here but I dont see the purpose of running coolers for rear diff, power steering, and trans when you may run 25 minutes a session at most?
Gaetano Cosentino
Old 12-31-2012, 04:14 PM
Roberts68 Roberts68 is offline
Mark
Trust me. If the trend continues it WILL be plenty COOL... even if the temp is a bit to the high side. I'm just sayin'...
