Old 10-04-2024, 02:36 PM
bk2life bk2life is offline
Originally Posted by TechNova View Post
the factory does it, but they're using completely different paint not available to us..
what paint are they using that is not available?
for the glass urethane to bond to.
i called a glass shop and they came by and applied their own 'window primer' to the metal where the urethane will go. Then they said to mask off their 'primer' and do whatever i needed to do.
When done, peel the tape off their primer and it'll be ready for the urethane to be applied.
The Following User Says Thank You to bk2life For This Useful Post:
camcojb (10-04-2024)
Old 10-04-2024, 05:21 PM
So yes I removed the sway bar mount..
Did some more hacking on the frame to get the airbags to fit and not rub.
Hooked up some airline and gave it a few up down tests. (down is the fittings leaking at the airbags, theyre only hand tightened..)
The new bushings squeak, but at least it goes up and down in the front, and I can grease them after powder coating.
Next is to tackle the rear air ride and 4 link bars.
-----> small video https://www.youtube.com/watch?v=xEP62aCrY-E
....one step closer
The Following 3 Users Say Thank You to bk2life For This Useful Post:
camcojb (10-04-2024), syborg tt (10-11-2024), WSSix (10-04-2024)
Old 10-04-2024, 08:22 PM
TechNova TechNova is offline
The glass company window primer is a 1K product and is typically used to cover bare metal from scratches caused by removing the old adhesive. I would not use that for large areas. A 2K epoxy is the recommendation from the auto makers. You really should be using epoxy first on all bare metal anyway so it becomes a no brainer.
It is possibe there are some primer advancements, I need to do glass in a week or so, I'll ask around. Glass work is unregulated and shady things happen. I'd ask for training documents before using a glass company.
Paint answer:
Not sure exactly what it is but paint companies tell me it is different, they bake at much higher temps. I aslo think they are uncatalyzed with heat instead of chemical cure. They also use different application method, bell sprayers. For PPG, DuPont and SW that I have used there was automotive finish paint (OEM) and automotive refinish paint (us).
The Following User Says Thank You to TechNova For This Useful Post:
Old 10-10-2024, 06:30 PM
This evening i was able to weld up all the holes on the window frame.
And i started rounding the upper outer corners.
Tomorrow ill finish the metal work, add some bondo, and get the first coat of primer sprayed onto the window frame.
Will need to block it out, and primer again before spraying on the color.
I want to get this to the glass shop asap so there is no excuse not to have it completed by the dec car show im trying to make...
camcojb (10-10-2024), fleet (10-11-2024), syborg tt (10-11-2024)
Old 10-11-2024, 05:11 PM
Good luck making that show!
Old 10-11-2024, 06:16 PM
ugh, dont jinx it !!!
Tonight I did the first round of body work to the window frame.
Possibly tomorrow i can block the areas and reprime it.
It is plenty straight i could paint it now, but, i want to finger the inner window areas another round before i paint it.
The Following 2 Users Say Thank You to bk2life For This Useful Post:
camcojb (10-11-2024), syborg tt (10-14-2024)
Old 10-13-2024, 03:25 PM
Today, slightly hung over, i wet sanded the window frame and sprayed the base/clear onto it.
Tomorrow I'll drop it off for the flush mounted glass to get cut and installed.
The color is a tri-stage, grey base, violet pearl and then clear.
I had planned on gold pearl, but i didnt have any when i thought i did. So i grabbed the violet to see how it looks.
Now that this window frame is completed, i can get back to fabrication...
camcojb (10-13-2024), syborg tt (10-29-2024)
Old 10-14-2024, 10:08 AM
photoshopped a 'window' in to see how it should look when i get it back..
i think only the 'purists' will even noticed the work i did to this windshield frame.
camcojb (10-14-2024), syborg tt (10-14-2024), WSSix (10-26-2024)
