Old 01-14-2007, 12:35 PM
radrambler's Avatar
Default ls1-4l60e in rambler A problem
hi guys
i dropped in a borrowed lsx motor and 4l60e today..whoooo hooooo
BUT DOH!!!!
with the motor @ 4 DEGRESS AND centered in the frame i have one problem.
my steering knuckle is right where the oilpan bolts to the motor..F@CK
i had to drop the vette oil pan off to get the motor in because the wings on the pan hit the mounts that come off of the crossmember when trying to put the motor in.....F@##n car building sucks sometimes....
MY crossmember and steering was all based around a lt1-4l60e.....and i just had to be a MEMBER OF THE NEW SCHOOL WITH AN LS1..IM NOT STUPID AND THIS LOOKS LIKE A REAL PROBLEM THAT MAY FORCE ME BACKWARDS ...NOW IM NOT SURE WHAT TO DO!!!!! DAMN THIS IS FRUSTRATING
ANYBODY?
PICS ATTACHED
RADRAMBLER
Old 01-14-2007, 04:38 PM
radrambler's Avatar
Default Im Ok Now
WELL
looks like ill notch the oilpan and may have to move the rack a fraction left of center....
i was a lil fired up earlier.... i talked with a friend who has alot of car building knowledge and this is what im gonna have to do to make it work...
anyway ill make it work
radrambler
Old 01-14-2007, 05:46 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Dang that is tight! Notching it is!
Old 01-15-2007, 11:27 AM
Musclerodz's Avatar
Ditch the vette pan and get a f body oil pan
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-15-2007, 11:32 AM
Rybar's Avatar
Rybar Rybar is offline
Mike
That is what I was thinking, most swappers run the F-body pan because the vette pan will not work.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 01-20-2007, 01:00 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
BOLT-ON PARTS . WHATS THAT?
Now where did i read this...
Keep it up! Its worth it!
Lead
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 01-20-2007, 02:01 PM
radrambler's Avatar
Default yep
yes
i know ....its going to be "fun" i think i have the issue solved..im taking the car to a local fab shop to finish the making brackets and final weld some thick stuff....THANK GOD...IM GOING TO GET THE BODY ON A CART/TRAILER AFTER THAT AND PREP IT FOR PAINT.ALL SUSPENSION WILL GET POWDER COATED WILL IM DOING THIS....PROGRESS , LOVE ME SOME PROGRESS...
RADRAMBLER
Lead
Old 01-28-2007, 09:36 AM
radrambler's Avatar
Default engine bolts in
yeah!!!!!!!
i didnt have to take my car to the fab shop .mild to wild fabrication.
i went over and helped him with some other customers stuff and i got my mounts built ...after much measuring and measuring and oh yeah more measuring... i made templates and figured it out...got the peices cut and welded up and BAM !!! IT BOLTS IN
I ALSO RAISED THE TRANSMISION IN THE TUNNEL 1 1/2 INCHES .the original eng- trans set way low.... too low... by raising it and then building the mount plates..i just have to get the camaro pan notched for my steering knuckle@ the rack.....sometimes you just have to measure and look and measure and look......cant give up though....anyhow i threw in and older start of build pic
look at the difference of when i started with the lt1 in the stock front end and the ride height difference...damn ,big difference
radrambler
Old 01-28-2007, 10:26 AM
novanutcase's Avatar
novanutcase novanutcase is offline
Lookin' good Brother! Lookin' good!
