Old 04-08-2007, 09:45 PM
awr68's Avatar
awr68 awr68 is offline
Originally Posted by jack67rs
looks good, wonder what it would run to anodize it black? what are your plans for plumbing? Is it an rs front end?
I will be using all 3" plumbing, not sure what material yet though...haven't decided what finish I want in the end. I have to decide soon though!
I will be routing the inlet threw the core support and the outlet will fit perfectly under the core support next to the frame. This is nice since I can still mount the radiator catch can and a/c drier (back to back) on the c/s.
I have a standard front end.
Are you thinking of adding an IC?
Tony
'68 Camaro
Old 04-08-2007, 10:54 PM
tyoneal's Avatar
tyoneal tyoneal is offline
I'd leave it the way it is:
1) Maximize Cooling
2) Put money where it shows, or makes more power
My $.02,
Ty
Old 04-08-2007, 11:27 PM
ArisESQ ArisESQ is offline
if you really want it black i think you may have to annodize it.
i know paint and powdercoat will affect how well the fins actually transfer heat, so you wont want to do that....
Old 04-09-2007, 07:36 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Looks good Anthony. I just got a P1sc also have have been looking into intercooling it. Looks like a nice option. Do you have any contact info?
Found them, thanks though.
Mike
Old 04-09-2007, 05:13 PM
jack67rs's Avatar
jack67rs jack67rs is offline
Anthony, I had an IC, but with the rs grill the headlight doors really screwed with the way I was going to plumb it. I'm only running 8-9 psi and so far it works fine the way it is. I used two stainless donuts on mine, one 3" out of the blower and a 3.5" on the inlet side ducted to the other side of the inner fender.
Old 04-09-2007, 10:01 PM
sc68z28's Avatar
sc68z28 sc68z28 is offline
I think they look cool unpainted. Yours sure fits nice .
Here's mine.
---Bill.
Old 04-09-2007, 10:09 PM
awr68's Avatar
Jack your ducting looks great! Did you TIG it and then gring down the welds...it looks seemless!! Did you have to build the transition at the TB? If so I bet that was a slow process!! Did you bead roll the end of the tubing?
Your car really turned out nice!!
Tony
'68 Camaro
Old 04-09-2007, 10:11 PM
awr68's Avatar
Here's mine.
---Bill.
Looks good Bill! Who built that IC? Got any more pics/specs??
Tony
'68 Camaro
Old 04-09-2007, 10:20 PM
sc68z28's Avatar
Thank you, it's a Procharger 3" 3 row, race.
---Bill.
68 Camaro, F1 Procharger, EFI, 5 speed.
9.40 et vid https://www.youtube.com/watch?v=O68yeamBteI
Old 04-09-2007, 10:48 PM
jonny51 jonny51 is offline
Anthony,mine is painted black.It should be running shortly,I will let you know if there are any problems but I doubt there will be.
