Old 05-07-2007, 10:10 PM
silver63c10's Avatar
silver63c10 silver63c10 is offline
Default Yup..I'm new - 79 Camaro Project
Hello all, been here several times so I finally decided to join. Some very nice cars here, good info too. On to the car, it's a 79 Camaro, just a backyard, low-budget, father-son, ground up rebuild type thing. Anyway, here's the basic info and some pics:
Chassis:
Comp. Engineering SFC's, 12 point cage, solid motor mounts
Suspension:
Front: SPC rod end adjustable UCAs, reworked mount position, solid bushings in lowers, QA1 bolt in adjustable coilovers
Rear: Stock Car Products Truck arms, QA1 adjustable coilovers, custom fabricated panhard bar/mount
Drivetrain:
11.5:1 377, Renegade CNC ported heads, solid roller, lightweight crank, Mahle pistons and h-beam rods (can't remember the brand), Fidanza aluminum flywheel and SPEC clutch, TKO600 and 9" rear with nodular case, 4.11 spool for now.
Tires & Wheels:
Sumitomo HTR Z's, 245/45-17 front, 275/40-17 rear, Cragar Soft 8's, 17x8 front and 17x9 rear
Body:
Fiberglass cowl hood, clear headlight/blinker covers, leaning toward Atomic Orange Metallic right now, but we know how that changes..
Pics and full info here
And a few pics...
Old 05-08-2007, 01:49 AM
almcbri's Avatar
almcbri almcbri is offline
that thing looks sick! Nice work. You don't see too many late 70 camaros being built. Keep up the good work.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 05-08-2007, 05:34 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Very cool, keep us posted.
And welcome aboard.
My LS7 69 Camaro
Old 06-24-2007, 03:45 PM
Got it on the ground this weekend, finally. Only took two years to do the front and rear suspension. Rest of the car should be relatively easy in comparison..
Duston
Follow along on the insta
Old 06-25-2007, 03:23 PM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Very cool .
Can I have your back yard ?
David
