Old 05-16-2007, 07:50 PM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
Default S-Curve a clean bottom..
The chassis is about done, I need to finish the rear brake lines fuel lines and exhaust up so I decided to strip the bottom of the body to paint it, I like a finished car top and bottom, so off with that 70's inch thick undercoat and WOW what a clean old car, I knew it was clean but not this clean, so about 40 bucks in chemicals and the steam cleaner we have a nice clean paint surface to work with, so far about 9400.00 in the project and 90 percent of the stuff to finish it.
Old 05-16-2007, 07:55 PM
LateNight72 LateNight72 is offline
Nice. Wish my A-Body was that clean underneath.
What type of "chemicals" were used?
-Todd
Old 05-17-2007, 05:26 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
-Todd
Yeah, and what type of "steam cleaner?"
Old 05-17-2007, 07:30 AM
The steam cleaner is a older Aaladin, I ran it at 225* and took most the grime and undercoat off, then used brake cleaner to soften the rest of the undercoating, another pass with the steam cleaner and a final bath with aircraft stripper. worked quite nice and was not alot of money.
Old 05-17-2007, 08:46 AM
oldzzy's Avatar
oldzzy oldzzy is offline
Man does that thing look solid! Nice work.
Shane
70 Olds W31 clone
http://www.flickr.com/photos/85638053@N00/
Old 05-17-2007, 11:48 AM
T Bell T Bell is offline
Super clean!!!!!!!! Did the factory not paint the undersides? I sure doesn't look like it.
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 05-17-2007, 01:58 PM
G-TX's Avatar
G-TX G-TX is offline
That's a very clean car!
I stripped my '67 GTX floor and frame down to the metal with one coat of Easy-Off oven cleaner...It's got to be the original formula,and wear protection.It'll eat you alive!!
Old 05-17-2007, 03:54 PM
slownova slownova is offline
i might of missed what motor is that? and who makes the supercharger brackets? thanks.
Old 05-17-2007, 04:54 PM
Steve1968LS2's Avatar
Sweet!
That's a great idea for ridding the car of the grime..
Old 05-17-2007, 07:05 PM
Its a 455 Olds, I tried to clean up the olds and give it a better look, As far as the brackets I made them still working on some of them to keep it clean, I have quite a few Prochargers laying around and decided a little psi never hurt, My old business did alot of work for Dan Jones owner of ATI, In the early years of Procharger, and I still have alot of stuff left from R&D.
