Old 05-28-2005, 02:10 AM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
Default TKO 600 question
Does anyone know if I will have any problems installing TKO 600 in my 69 camaro If I am currently running ½ inch drop global west solid body mount bushings.
Also what would be the best parts to run with this tranny.
example :
-hydraulic verses manual
-brand of clutch, scatter shield.
My car is making about 600 hp and 600 ft-lb of torque.
Old 05-28-2005, 02:46 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I'm not sure about the drop bushings, but for the clutch and bellhousing, I had great luck with my CenterForce Dual Friction and the McLeod bellhousing/block. The Bellhousing and block plate were very high quality pieces and I'd highly recommend going that route.
My LS7 69 Camaro
Old 05-31-2005, 11:06 AM
rockdogz's Avatar
rockdogz rockdogz is offline
Default classicchevy5speed
I'd highly recommend giving Jeff from ClassicChevy5Speed a call at 760-230-2045. He's a great guy and helped me out with my TKO-600 even though I bought from Keisler before I knew of Jeff.
-Tom
camarorestoration.com
Old 05-31-2005, 06:37 PM
Default hydraulic verses manual clutch...
I wanted to run a hydraulic clutch. Is there any reason why I shouldn't.
Doe's anyone know any pro's and con's to running a hydraulic verses a manual clutch.
Old 05-31-2005, 07:19 PM
camcojb camcojb is online now
Run the hydraulic. Super smooth, no header clearance issues, etc.
Old 05-31-2005, 09:55 PM
Blown353 Blown353 is offline
I'm in the opposite camp-- If you have no header clearance issues, run a mechanical clutch with good quality heim joints everywhere. Just as smooth as a hydraulic clutch, cheaper, and with less chances of something leaking brake fluid and eating your paint.
Personally, after putting the heim joint clutch linkage in my car, I'd only run a hydraulic setup if there are header clearance issues. My linkage is extremely smooth! I also like how an all-mechanical setup transmits a bit more "pedal feedback" about the clutch take-up and what is going on. Although, the hydraulic setup allows for easy tailoring of clutch pedal throw/weight by altering the MC bore size. You can do the same by adjusting the pivot points on a mechanical setup, but you need to double check everything to make sure you don't go over-center at some point and "stick" the linkage down.
However, a good hydraulic setup will work just fine and knowing you have a BBC in that Camaro makes me think hydraulic will be the easiest way to go. It would probably be tough to snake a Z-bar and all the linkage around the headers in a BBC camaro. Also, AFAIK that 502 doesn't have the provision on the block for a clutch pivot ball.
As far as a scattershield, McLeod all the way with Moroso offset dowels if you need them.
I also recommend McLeod for the clutch and flywheel. Very happy with my Dual Performance and billet flywheel.
1969 Chevelle
Old 05-31-2005, 10:30 PM
Troy, you just love to argue!
Old 05-31-2005, 10:31 PM
NO I DON'T!
1969 Chevelle
Old 05-31-2005, 10:39 PM
Old 06-01-2005, 12:30 AM
Thanks for the input, much appreciated.
I'm not planning on ever racing the car so I just want to make it more fun for street driving. I find my TH400 really boring.
