Old 09-03-2007, 01:18 PM
vinz68's Avatar
vinz68 vinz68 is offline
Originally Posted by ProdigyCustoms
Excellent work. How does it clear the Shockwave? Seems like this is the worst area of concern.
I do not want to steal the thread, but since people will be looking at exhaust ideas.........Here is what we did on Project EmptyNest. Because it is a mini tub, tail pipes are even more difficult to snake the pipes around the Shockwave and tank. So we went over the suspension. Seems to work out great, and minor fabrication for anyone already in doing tubs.
Nice work Frank, I mounted the compressors and air valve controller where you came through the trunk area, where will you be mounting that stuff? I thought about mounting the compressors under the car but i couldn't find a good spot.
Vinnie
www.fquick.com/vinz68
Old 09-03-2007, 01:41 PM
68protouring454's Avatar
by about an inch, i also wrapped the exhaust in that area to keep heat down just a bit more
Jake's Rod Shop
Old 09-03-2007, 01:46 PM
The tank will sit right between the 2 humps almost lined up even with the vertical trunk trim panel we will install just below the hinges. Were making the tank pretty and exposing part of it through the trim panel. The compressor and other hardware will sit hidden in that compartment also.
Frank Serafine
Old 09-03-2007, 01:57 PM
vinz68's Avatar
Very nice I can't wait to some pics. I wouldn't mind cleaning mine up a bit.
Vinnie
Old 09-03-2007, 02:35 PM
Jake's Rod Shop
Old 09-03-2007, 03:07 PM
Steve Chryssos's Avatar
Mufflers are SpinTech's Pro Mod Shootout series. Very loud.
________________
Steve Chryssos
Ridetech.com
Old 09-03-2007, 03:28 PM
Clearance is decent if you don't mini-tub and you run oval pipe. Lots of guys with custom rear suspension choose to run turn downs instead of tailpipes. That was not an option here. Custom tailpies are the only way to go.
________________
Steve Chryssos
Ridetech.com
Old 09-03-2007, 03:40 PM
with a narrowed tank the same set up would work perfect, only difference would be the 90's going out around tank would be shorter
Jake's Rod Shop
Old 09-03-2007, 05:30 PM
Steve1968LS2's Avatar
Cool deal.. 68s are going to REPRESENT at SEMA this year.. show that 69s arn't the only first gens
Old 09-06-2007, 07:41 PM
vinz68's Avatar
Saturday is the big day! I get my car back! Then Pigeon Fordge on thursday. Thanks for a great job Jake , hope you can make it to Pigeon Fordge.
Vinnie
