Old 09-26-2007, 05:22 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Mud work, Did I mess up?
All my body work is finished except the hood, today I started doing all the metal work and grinding and with out thinking I started all the mud work, Look great. But I for got about the dam epoxy. what's my chances?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 09-26-2007, 05:34 PM
68protouring454's Avatar
no worry s, as long as its in an insulated shop its fine, either finish body work and use some etch primer on base metal areas, or epoxy, then prime. no big deal i only epoxy if i am going to use polyester primer
jake
Jake's Rod Shop
Old 09-26-2007, 05:47 PM
bigtyme1's Avatar
jake
Thanks Jake, I do paln on using Standox spray polyester once the major body work is done. Can I epoxy over the mud then spray the polyester?
69 RS Ragtop
[email protected]
Old 09-26-2007, 06:20 PM
J2SpeedandCustom J2SpeedandCustom is offline
Yep. Epoxy the whole car that way the bare metal is covered as well. Then lay on the poly.
Jeff Allen
J2 Speed and Custom
Old 09-26-2007, 06:34 PM
bigtyme1's Avatar
Thanks Jake now I can sleep
69 RS Ragtop
[email protected]
