12-19-2007, 07:56 AM
anyone have a drive shaft
im looking for a driveshaft that will work for my 69 camaro witha 700r4..either one that is for this application or one that i can cut to make work ect..let me know what you got this is the last thing i need to get the girl back on the road with the new tranny..
1969 ss 350,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......cusotm interior, 2 tone paint and front frame all in the works
12-19-2007, 02:12 PM
Where are you located. I have one I just pulled off my th400. You might be able to make it work.
12-19-2007, 07:24 PM
im located in souther louisiana..i wonder what it would be to ship that thing..
12-19-2007, 07:35 PM
I have a stock shaft from a 69 camaro with turbo 350. You would need to have it shortened. I am in Pensacola. Shouldnt be too much to ship. Scott
12-19-2007, 07:40 PM
what do you want for it..or even a questimate on shipping
12-20-2007, 10:35 AM
Save yourself the shipping dollars and pick up a used shaft at the junkyard. Any Astro Van, truck or S10 that had a 700R4 will have exactly what you need.
Are you still running the stock rear? You may be able to re-use the stock driveshaft by swapping on a new yoke with an "adapter" u-joint... Something to check into.
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
12-20-2007, 10:00 PM
my stock drive shaft is toast broke on me doing 80 on the interstate this is why im doing the tranny swap. kinda tore up my old one..and yes i am useing the stock rear..so at a wrecking yard what would i be looking at for a donor
12-21-2007, 08:45 AM
http://www.thrashdriveshaft.com/
their shafts are made to order and are top quality..it will probably not cost much more than having a shaft cut...
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
