Old 07-15-2005, 04:28 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Default Rick's Hot Rod Shop stainless tank
The stainless tank that I ordered from Rick's Hot Rod Shop arrived today. It's narrowed for the mini-tubs, has integrated sump and baffling for EFI, has a -10 pick up and -8 return, a GM 90 ohm sending unit, and is slightly deeper to make up for being narrowed. It should be right at 16 gallons.
It looks fantastic, the craftsmanship is first rate. Thanks again to all the guys at Rick's.
My LS7 69 Camaro
Old 07-15-2005, 05:03 PM
I like it!
Old 07-15-2005, 05:44 PM
race-rodz race-rodz is offline
stupid question.... where is the vent? vented cap only?
Old 07-15-2005, 05:58 PM
Steve1968LS2's Avatar
Vents suck.. run a vented cap..
Well at least mine did.. nothing but trouble till I capped it off and swapped the cap.
I need to contact Ricks about Penny.. she needs a REAL gas tank..
Old 07-15-2005, 06:06 PM
BC69's Avatar
BC69 BC69 is offline
Looks awesome...sucks that it has to get put under the car...sometimes you want to display even the gas tanks!!
Tim
In memory of those gone before us
In gratitude for those who care.
Old 07-15-2005, 06:52 PM
XcYZ's Avatar
There are threaded bunges on either side of the sending unit that are for hooking as a vent.
My LS7 69 Camaro
Old 07-15-2005, 07:06 PM
Rick@Rick's Hot Rod Shop's Avatar
Rick@Rick's Hot Rod Shop Rick@Rick's Hot Rod Shop is offline
Just a quick NOTE about our vents... Unlike other tanks with vents our vent provisions are different. The bung extends down aobut 2.5" into the tank they will accept a roll over check valve, and have a piece of 5/16 tube welded to it that goes to the highest part of the tank. This in effect greatly minimises the amount of fuel that can possibly exit and also cuts down on fumes.
Old 07-16-2005, 12:24 AM
i saw the tape next to the sender.... wasnt sure if they were vents or not, since they would greatly lower the fuel level...but the bent tubes/check valves make sence.... i get it now. thanks
Old 07-16-2005, 01:07 AM
GO67SS GO67SS is offline
Default Just got my tank too!
I just got my tank also. Awesome craftmanship. Those guys do great work and pretty friendly and helpful. It took about 30 minutes to install because I have to find some damn wire connectors. I attached a hose to my vent for a charcoal canister down the road. The car started with no problems. I am happy customer. Best money spent so far!!!
Drive it like you stole it!
Old 07-16-2005, 06:19 AM
Steve Chryssos's Avatar
It's a work of art. Very nice. Is that the OE 69 filler location? It looks high--like a 67/68.
________________
Steve Chryssos
Ridetech.com
