Old 02-17-2008, 09:29 PM
Blown353 Blown353 is offline
Default shifter boots.
Quick question guys.
Right now I'm in the middle of rebuilding my entire trans tunnel (raised for reduced u-joint working angle & more driveshaft clearance.)
Anyways, I'm not going to be able to run my factory console anymore, so I'll just have my shifter poking up through the floor.
What's the ideal boot situation for this? I'd like a rubber boot to keep the fumes out but want something better looking (i.e. leather) over that. Just wondering what other people have done...
What I want is a final result similar to Mark's:
Thanks in advance...
1969 Chevelle
Old 02-18-2008, 07:04 AM
I have asked same once and i know today its Lokar shifter boot . You can get one easily from summit etc. But its only the fake leather boot and trim ring. You still need good rubber boot on the trans tunnel to seal fumes and noise. I have seen orginal T56 / F body rubber boots fore sale in ebay ( in case you have T56 trans )
63 Z06
Old 02-18-2008, 10:46 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I have an old beater rubber boot that I plan on putting in the floor, then use this Lokar boot and ring.
My LS7 69 Camaro
Old 02-18-2008, 11:52 AM
awr68's Avatar
awr68 awr68 is offline
Scott, what rubber boot are you using? Stock T56 F-Body?
Tony
'68 Camaro
Old 02-18-2008, 12:34 PM
No thats me with the T56 boot , Scott is using old beater rubber boot
And here you can have em both in same deal Old beater T56 rubber boot
http://cgi.ebay.com/ebaymotors/98-02...QQcmdZViewItem
63 Z06
Old 02-18-2008, 02:29 PM
awr68's Avatar
I'm thinking I would have trouble using one of those and my Lokar boot with the round trim ring.
Tony
'68 Camaro
Old 02-20-2008, 04:02 PM
rwhite692's Avatar
I am looking for a good solution as well (for the weather/noise sealing boot which will be underneath the Lokar "decorative" boot and trim ring)...
http://www.sealsit.com/firewall.asp
These guys seem to have some decent sealing rings...maybe I will give one of these a try. They are available through Summit.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 02-20-2008, 11:19 PM
I have bought few seals for them an i can say product and customer service is really good. But i dont think you find big enough for shifter body from them.
63 Z06
Old 02-22-2008, 11:42 AM
I found this one in AMC parts specialist. Looks quite low profile and round. Most of the aftermarker shifters have round body. But i have no idea of the real diameter. Mayby some one closer could give em a call and ask?
http://www.americanpartsdepot.com/Tr...nShifters2.htm
5" diameter!!
63 Z06
Old 03-12-2008, 05:49 PM
Silver69LS1's Avatar
Silver69LS1 Silver69LS1 is offline
[QUOTE=XcYZ]I have an old beater rubber boot that I plan on putting in the floor, then use this Lokar boot and ring.
Scott,
I'm putting a 4l80E w/ Paddle shifters in mine. I want to avoid putting one of those goofy plastic boxes (B&M, Hurst) on my floor. I won't be running a console. I like the lokar boot you have in the pic. What shifter is under that boot? Is that AOD Billet knob Lokar too?
Thanks,
Rich
1969 Camaro
Twin Turbo LSX project in progress
