Old 04-20-2008, 09:18 PM
murtah's Avatar
murtah murtah is offline
Looks great Tom. Thanks again for the deal on the pan. Did the check make it back to you yet?
Where are you going to mount your coils? behind the heads?
Jim
Old 04-20-2008, 10:20 PM
Jr's Avatar
Jr Jr is offline
I thought dp90 was black? Nice to see progress on the car. Did you media blast the car? If so, where?
Old 04-20-2008, 10:54 PM
Tom.A's Avatar
Tom.A Tom.A is offline
I am not sure on the DP90 as when he put it on I was not there. The pictures above is after DP90 and it is UPOL primer.
I had it media blasted at a company called Advanced Finishing Systems in Riverside, California. It was about $500.00.....that was body, doors and trunk. No front sheet metal as it was all trashed. They did it quick, however my spanglish is not very good so if you use them be sure to point things out that you want and don't want done.
Thanks,
Tom
Old 04-20-2008, 10:47 PM
Tom.A's Avatar
Jim
Jim,
Thanks and yes I did get the check and thanks for the additional, I did not expect that so thank you very much. I look forward to seeing some posts on your project.
As for the coils I hope to put them behind the firewall. If it turns into a problem I will look to the back of the heads or some where down on fender wells
Tom
