Old 06-05-2008, 10:19 PM
abadsvt's Avatar
abadsvt abadsvt is offline
Default Hard Line Fittings..... Where to buy?
I was hoping to run all my air lines, fuel lines, brake lines and so on all in stainless steel tubing. I have been trying to find a good supplier for the fittings. I heard Swaglok was the fittings to use but I priced out 1 stainless fitting for $54. I am going to need a fair amount of fittings and was hoping to find something a little cheaper but still quality pieces. Any help would be great!
Josh
Old 06-05-2008, 11:28 PM
ironworks's Avatar
I stock quite a few, I get them from a supply house in Northern California. I also stock the tubing in 20 ft straight lengths. It is much easier to make straight nice tubing from straight tubing, not the coils that make it easy to ship. I buy both the tubing and the fittings in bulk to help on price. The nuts and sleeves are not that much but a TEE bulkhead could be 54 bucks.
If you make me a list of what you want I can tell you if I have it all in stock.
Rodger
Old 06-06-2008, 05:09 AM
americansupercarinc americansupercarinc is offline
Try these guys they carry every thing stainless and rubber
Amazon Hose & Rubber Company
1103 N 50 St
Tampa, FL 33619
813-223-7554
Old 06-06-2008, 05:43 AM
Contact Mark ,aka bentfab here in forum. He is a real professional on hard lines as well as super nice guy to talk with.
http://www.bentcustomandperformance.com/
63 Z06
Old 06-06-2008, 07:38 AM
Fluid Power's Avatar
...and you do not want to use AN fittings?
Old 06-06-2008, 09:38 AM
abadsvt's Avatar
Rodger
I will put together a list and let you know. I can see that using the 20' lengths of tubing would be nice for those straight runs. Do you use tubing cutters to cut the stainless tubing? I am still figuring out what i will need but i think most of my fittings are just male connects. One side thread and the other is a compression fitting. I will need a few that are a 90deg instead of straight ones. Here is a pic Do you have an idea on what this fitting would cost? My air lines are only 1/4". Thanks Rodger!
Josh
Old 06-06-2008, 09:40 AM
abadsvt's Avatar
I am new to doing hard lines so I always thought that you use AN fittings when doing fuel only and possibly brake lines. Do people use these for air line fittings?
Josh
Old 06-06-2008, 09:42 AM
abadsvt's Avatar
Thanks Americansupercarinic and bowtieracing for the links and contact info. I will check them out.
Josh
Old 06-11-2008, 08:16 AM
dave96dcm dave96dcm is offline
Go to mcmaster.com and search for Yor-Lok fittings. A example of the fitting that you are looking for is part number 5943K111 it is $9.83
Old 06-11-2008, 10:17 AM
ccracin's Avatar
ccracin ccracin is offline
That's good advice Josh.
If your interested:
Chad
Instagram - @cctek
68 Chevy Pickup Project
