Old 05-29-2008, 08:11 AM
whytry's Avatar
whytry whytry is offline
Have fun in it Jody!!!
If when you get back and need a hand, even if its a food run let me know.
68 Camaro F1R Procharged LS build in progress.
Bagged, 4 Linked, mini-tubbed, n all out nasty!!!
Divorced with 2 boys, so its a slow progress, but its progress
Old 06-02-2008, 06:51 PM
67ssdan 67ssdan is offline
Car looks awesome man! Congrats!!
Dan
Old 06-02-2008, 10:16 PM
camcojb camcojb is online now
Dan
thanks Dan. I've been dinking around tieing up loose ends waiting to leave for Power Tour. I re-routed the breather and fuel lines, swapped valve covers, and got the paddle shifter to work. I knew it was a wiring issue, since I'd wired the car............ Steve at Twist Machine was very helpful in figuring out what was happening (or not happening). Turned out that it was a simple weatherpack terminal that had not been seated properly and had pushed out when I connected it, causing no voltage to the controller for the manual mode. Simple fix, works great now.
Can't wait to get back from Power Tour, turbo should be back by then, and I can start driving the car. I'll post up more final pics when I get the turbo installed.
Old 06-03-2008, 12:13 AM
JamesJ JamesJ is offline
The good news is that you will have the car in great shape when you take it on it first road trip.
James J.
Old 06-03-2008, 03:02 PM
mydally mydally is offline
wish i had time to dink around,,i use to dink around,but havn't dinkrd in a while....someday i'll dinker again...but for now i'll just work on don & brent's car an dream of dinking on mine sorry jody i'm at work an it sucks... plus i think it's time for a new mask
Old 06-03-2008, 03:56 PM
you're a funny guy Jim............
Old 06-03-2008, 07:38 PM
XcYZ's Avatar
XcYZ XcYZ is offline
You need to post more often, Jim.
My LS7 69 Camaro
Old 06-03-2008, 09:05 PM
Ricochet's Avatar
Ricochet Ricochet is offline
You know Jim..It is alright to dink or dinker all you want...as long as you dink or dinker on my car!!
Brent
Old 06-04-2008, 02:46 PM
Brent
what and how i fixed your door is way beyond dinkerin...it might be even be illegal in most states (but cleetus & bubba jr would be proud ) like i told you what goes on behind closed garage doors...
Old 06-20-2008, 11:39 AM
kwhizz's Avatar
kwhizz kwhizz is offline
O.K.........You are back from Power Tour........It's time to get back to work and finish the Car!!......................
Ken
