Old 07-19-2008, 09:18 AM
spchiv's Avatar
spchiv spchiv is offline
I'm doing a '61 Bel Air and put a Morrison chassis under it. I've been pretty happy with it, but it will still be a while before I get a chance to drive it. I'm thinking the rack and pinion, disc brakes, and lower center of gravity will make the car much more drivable, plus we set the engine back a few inches. I really like these '60s full size chevys.
Old 07-20-2008, 12:54 PM
V8TV's Avatar
V8TV V8TV is offline
Default RE: Biscayne
Here's a drag sleeper version... it's been posted here before...
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 07-20-2008, 06:47 PM
Mr.VENGEANCE Mr.VENGEANCE is offline
hey
are you by chance having your car built by Fuller?
Old 07-21-2008, 07:23 AM
spchiv's Avatar
Yes, Bryan is doing my car.
Old 07-21-2008, 07:57 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Originally Posted by JayR View Post
IMO, 4" is way too much difference in diameters and is why Troy put 20s all the way around his Biscayne which is the baddest 66 B-Body of all time.
18s will have room all the way around them in front with a car that size and 22s will be stuffed in the rear.
Don't look at Troy's car as a difficult challenge to surpass but as a template for ideas and inspiration. Just a twist on some of his ideas with your favorite color and wheels and you can't lose!
+100
Old 07-21-2008, 02:46 PM
darren@ridetech's Avatar
darren@ridetech darren@ridetech is offline
Actually we just finished designing some tubular upper and lower control arms for the front. We redesigned the lower arm to an A-frame style arm, with an adjustable bearing on the frame end. Ton's of caster available. Chassis Works makes a Wilwood brake kit for the stock spindles as well.
Old 07-21-2008, 02:51 PM
We also have the front & rear sway bars w/ the new PosiLinks and rear trailing arms w/ adj. panhard bar. More images here.
http://www.ridetech.com/catalog/Chev...70-2483-1.html
Old 07-21-2008, 06:15 PM
crazycarl's Avatar
crazycarl crazycarl is offline
IIRC, the rear upper control arms are the same as 67-72 a-bodies and the lowers are the same as g-bodies. Or it could be the other way around. Or I could be thinking of E bodies instead of B bodies.
Forget I even piped up.
I'm probably just screwing with you, so please don't take it personal.
Old 07-21-2008, 10:02 PM
syborg tt's Avatar
Bulldog - can't wait to watch the build.
the chicayne had
Front: 19” x 8” with Nitto NT555 Extreme, size 245/35ZR19
Rear: 22” x 10” with Nitto NT555 Extreme, size 285/35ZR22
Hurrican
had a 295 40 20 on the rear - nice tire
can't remember the front
ps i personally would go with Air Ride, leave the motor and drive the heck out of it.
marty-mj
