Old 08-12-2008, 10:45 AM
DOOM's Avatar
DOOM DOOM is offline
Default Best deal on Koni coil overs
Can anyone tell me who would have te best deal on KONI coilover shocks for my DSE QUADRALINK?? I am just about ready to pull this thing out of my storage lot. Im making sure I have everthing ready for mock up.
Mario
Old 08-12-2008, 12:16 PM
Efi69Cam Efi69Cam is offline
Save yourself the time money and headaches and just buy the ones from DSE. Their price is not all that bad either. Konis are pricey.
Old 08-12-2008, 02:46 PM
DOOM's Avatar
Thanx I guess im going to have no choise..
Old 08-13-2008, 12:19 PM
DOOM's Avatar
Well the next question is do I stay with the Koni or go with the QA1 ? My DSE SUB has Koni . Not to up on shocks to no whats best...
Old 08-13-2008, 06:04 PM
DSE designed the QL around that shock. It will be hard to find another one that will give the range of adjustment and proper ride height (of the shock). I tried, and was unhappy with the results.
I shopped around trying to find the Koni shock DSE uses and was not able to find a price that was cheaper enough than DSE to justify the risk that it might not be the exact one.
Old 08-14-2008, 07:01 AM
DOOM's Avatar
That ends that! Thanx for the info
Mario
Old 08-14-2008, 08:03 AM
68protouring454's Avatar
all that you need to know is what the shock length (eye to eye) at ride height, and how much compression rebound you need, generally on first gen camaros whether its stock or aftermarket chassis, a 5 inch shock works perfect.
that said a 5 inch shock can come in different installed height lengths. so if yo u set your project up at ride height and measure from center to center of the mounts this is your installed height, now you can look for shocks. this is important because you can adjust a coil over lower etc, however you loose valuable shock length when in compression, so you really want to measure at ride height, then tune 1/4 inch here or there.
Jake's Rod Shop
Old 08-14-2008, 08:24 AM
DOOM's Avatar
Never had it explained to me like this . THANK YOU!!!
Old 08-14-2008, 08:53 AM
remember that valving is key so if you get your own shocks it would be in your best interest to buy adjustable, so you can tune the ride, if not buying adjustable it would be worth the money to just buy the koni shocks from dse
Jake's Rod Shop
Old 08-14-2008, 09:00 AM
DOOM's Avatar
Thanx again. I like the adjustable route.
Mario
