Old 09-07-2008, 09:09 AM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
Default Need help lowering my 2dr Tahoe
Any body know of any parts to lower the rear of my 97 tahoe 2dr. other than just shackles . I have rear hangers for 2 inches, would like to go more than though, cant find any thing in the aftermarket though.
Old 09-07-2008, 09:16 AM
Blake Foster's Avatar
call a local spring shop and have them make you a set of lowered springs.
Blake Foster
www.speedtechperformance.com
Old 09-07-2008, 09:19 AM
Thought about doing that, or pulling a leaf out of the spring pack. Checkin to see if any body knew of anything or had any other Ideas. Thank you for the suggestion though.
Old 09-07-2008, 02:56 PM
JUSTANOVA JUSTANOVA is offline
http://www.belltech.com/products/gm/suv.htm#low_comp
you could do a "flip kit"
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 09-08-2008, 11:25 AM
whytry's Avatar
whytry whytry is offline
Is it 2 wheel drive or 4?
If it's 2, how low do you want to go? You could do Spindles and springs up front - 4" and do a flip kit in the rear and get 5.5..... Will sit pretty low.
http://musclesyndicate.com/m003.html
That's mine, in the 2nd pic that the above setup on 17's, then I made some of my own stuff and got it lower in pic 3 on 18's, then went to air....
68 Camaro F1R Procharged LS build in progress.
Bagged, 4 Linked, mini-tubbed, n all out nasty!!!
Divorced with 2 boys, so its a slow progress, but its progress
Old 09-08-2008, 12:06 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
www.fullsizechevy.com
Great source
FLIP KIT
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 09-09-2008, 09:41 AM
Thank you for the responses, guess i need to decide how far I want to go, I had looked at belltech's website and never saw anything available for a 2dr and now I see it there. I have already put belltech spindles and shackles on it and it is not low enough that way........Guessing I will probably do a flip kit.
Thanks again
Tommy Lee
Old 09-09-2008, 11:53 AM
CKTA CKTA is offline
Great source
FLIP KIT
Jeff
Thanks for the FSC plug....I'm a Mod. over there!
As for the 2 Door Hoe, I've lowered 2 of them. The Bell Tech (and or DJM) are actually a 4/5" drop. (4" in the front /5" in the rear)
For the front it's a matter of spindles and springs. For the rear it's a flip kit, but unlike the pick-up truck flip kits you only get 5" of drop (instead of 6") The reason being, you need to install the front hangers to raise it up another inch. You will also need to cut a good amount (3" high and frame rail to frame rail) of the rear crossmember right infront of the gas tank.
As usual you will need to C-notch the frame and grind and punch out the rivets for the front hangers. Not hard of a job at all, but time consuming. If you need any other help check me out over at fullsizechevy.com under the same user name or just check out and search on the site over there....alot of good info.
