Old 09-08-2008, 04:05 PM
Nate Hanson Nate Hanson is offline
Default Lokar Throttle Cable
Hey guys, I purchased a universal Lokar throttle cable for my s10, but the part that attaches to the cable itself does not match up with that "fork" like the stock cable does, has anyone come up with a solution to this?
Thanks!
Nate
-1991 Chevrolet S10-
S-Series Big Brake Kits! CLICK HERE!
Old 09-08-2008, 04:25 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Nate, you mean the clevis? It doesn't fit the carb?
My LS7 69 Camaro
Old 09-08-2008, 04:32 PM
Other end, it doesnt fit on the actual pedal itself, the stock cable had this plastic peice that clipped into there, its hard to describe. I can take a picture if that helps?
Nate
sounds like he's talking about the pedal. It is shaped like a fork on the end with a barrel-shaped deal crimped on the cable to hold it to the pedal arm.
Old 09-08-2008, 04:39 PM
XcYZ's Avatar
Gotcha. I don't have a throttle cable, I'm no help. lol
Nate, take a pic.
My LS7 69 Camaro
Old 09-08-2008, 04:54 PM
Here is what the lokar cable looks like:
Not my truck but the pedal connection is the same.
Any suggestions?
Old 09-08-2008, 05:23 PM
Any suggestions?
I don't see why you can't use it as is. There is the clevis deal on the end, think of that as the barrel deal on your stock cable. Drop the cable down the slot and the clevis holder will keep it in place from pulling through. Hole in the firewall with that fitting and nut, and you're set.
