Old 09-18-2008, 04:43 PM
Originally Posted by novanutcase View Post
I saw the tubs so I'll give you my view. The DSE tubs are rounded whereas the Ironworks tubs are squared off at the inner turn so that the square of the tire can fit inside better. Does that make sense?
John
Sure does thanks for the input but I have seen some prettly low Gen1 camaros with the DSE tubs and monster tires. Empty Nest has 315's I think
Personally I am not into the huge 315's I would be happy with a 285 40 17.
if I could get it nice an low.
Old 09-18-2008, 05:55 PM
skatinjay27's Avatar
are the 67-68 outer wheel wells differet than the 69s? cause todd(vegas 69) has 345s with dse tubs and g-bar it it pretty low and still clears... but its very tight.
AJ
Old 09-18-2008, 06:00 PM
I was wondering the same thing because my 68 has 335s with the Air Bar and there is room for 345s if we wanted to apparently....
Old 09-18-2008, 06:22 PM
awr68's Avatar
awr68 awr68 is offline
There is a differance between the 67-68 and the 69 outer...the 69 has a .75" wider outer.
Tony
'68 Camaro
Old 09-18-2008, 07:01 PM
ironworks's Avatar
The car sits lower then the G bar will go. If I put a wider tire, it would hit the lip of the fender due to the over hang being closer to the tire. The lower link on the G bar is just a tick below level if that gives you an indicator how low this car is. I could fit a 345 if we wanted to raise the back of the car. We will have to modify the upper shock mount to be able to run this ride height. The mount under the bar design of the upper shock mount is just a waste of space in my opinion and a poor design, cheaper to build but a waste of space. It motivates me to start on my own rear suspension kit. We will be changing that mount design when the car is totally disassembled and more able to get underneath. Right now the coil over spanners are against the adjuster knobs. If I ran it like this I should run a shorter shock body with a stiffer spring just to avoid bottoming out.
I hope this clears up any issue. Ride height and stance are key factors in all the cars we build. We find the deesirable ride height and modify everything to make it fit from there. I told brian (63 nova customer, Brian Mc )last weekend that every extra inch lower is like 10,000 more in some instances just to not have the headers drag and suspension bottom out and tires that rub. That is why Johns 66 is difficult, the ride height and the amount of crap in that car.
Old 09-19-2008, 03:35 AM
Thanks for the info! It really helps the DIY guys like me! "It motivates me to start on my own rear suspension kit" That would Good news always looking for cool stuff.
Old 09-19-2008, 02:41 PM
novanutcase's Avatar
novanutcase novanutcase is offline
Thats BEAUTIFUL crap to you sir!
John
Old 09-19-2008, 02:45 PM
rich-allen's Avatar
rich-allen rich-allen is offline
Tell us what you really think
67 RS/SS
Old 09-19-2008, 08:37 PM
brian mc's Avatar
brian mc brian mc is offline
QUOTE] I told brian (63 nova customer, Brian Mc )last weekend that every extra inch lower is like 10,000 more in some instances just to not have the headers drag and suspension bottom out and tires that rub.[/QUOTE]
i thought dragging headers was the new IN thing to do....
Rich your car is lookin sick. I like it with the blower, can't wait to see that thing on the road. there are going to be some bad ass rides coming out of that shop pretty soon what with the 57 truck and your car, that will be cool to see. Did you decide on some wheels yet?
Old 09-20-2008, 09:10 AM
rich-allen's Avatar
Brian,
I never imagined how secure I would feel with my car being completed by someone else but Rodger makes it so easy and the quality of his work is really starting to show.
My car is a totally different project from the norm Ironworks puts out put I think when the Novas come out to play Rodger will really have his hands full with clients clamouring to get their projects in his shop.
We will have to get together on the play ground as soon as your car is completed.
Are you planning a trip to the shop anytime soon?
Rich
67 RS/SS
