Old 10-20-2008, 02:05 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Originally Posted by ProdigyCustoms View Post
A few things Ty,
First off, you will be using a 140-9803 that replaced the 140-7019. The 140-9803 is a radial mount and has even better caliper to spoke clearance then 140-7019. This is a god thing for you with the problem you have with your wheel clearance.
As for spindles, if you do not want a tall spindle that has drop ion it, you are going to be forced into stock spindles and a G mod. or stock spindles and a tall upper ball joint
As for subframes that use stock spindles, look at Speedtech. This is what we run in Project EmptyNest and we are very happy with it.
Frank:
Thanks for your input.
I have read on a number of links that the dropped spindles are definitely NOT the way to go if you want to keep the steering geometry in tact.
I'm guessing that information is still valid.
While I'm trying to find the most desirable way to go with this, would you mind sending me a quote regarding the:
Wilwood Radial Mount Big Brake Kit
The Tall Ball Joints and spindles
The Speed Tech Front Clip
Why would people not always use a radial mount Braking system, since they could then have more wheel choices?
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
